Help asap
Old Dec 13, 2009 | 06:16 PM
MaxxKid's Avatar
Help asap
ok guys i chaned my air filter to aftermarket so I unpluged the maf and had to mover the car so the car was ran without the maf pluged in just to change parking spots then the check engine light came on while i was moving the car, when I was done changing the filter the check engine light never went off so i unpluged the battery to see if that will work but it didn't and now the car is hard to start. any idea on what could be wrong OH yes i did plug back in the maf cable
Old Dec 13, 2009 | 06:18 PM
TLMNICK's Avatar
A simple SEARCH would've showed you the proper method for pulling codes from the ECU, and clearing those codes to get rid of the engine light. It's in the stickies!!
http://forums.maxima.org/4th-generat...ere-first.html
Old Dec 13, 2009 | 06:23 PM
MaxxKid's Avatar
ok and about the car not wanting to start
Old Dec 13, 2009 | 06:41 PM
aackshun's Avatar
A. take a deep breath, calm down
B. Tell us the code first
C. Then describe the irregular starting (in detail)
Old Dec 13, 2009 | 08:07 PM
Conrad283's Avatar
I need a truck
Check all the connections leading to the MAF. Check any hoses that you might have taken off. Check to make sure the MAF is installed the correct way.
Is this your rb26 swap maxima?
Old Dec 13, 2009 | 08:10 PM
FallenOne's Avatar
did you seriously do that swap?
Old Dec 13, 2009 | 08:31 PM
tyler5619's Avatar
lol at a dude about to have an rb26 maxima can't install a cone filter without fuxing it up.
but to be honest, i forgot to plug my maf back in after changing my fuel filter (i took the plug out for more fat arm room), and forgot to plug it back in. had to take a trip to the auto store to clear the code out. other than that, no issues resulted. if your car doesn't start right, something else got messed up.
Old Dec 13, 2009 | 10:17 PM
G4nismo's Avatar
do a barrel roll
Old Dec 14, 2009 | 06:32 AM
cashoit's Avatar
when u swapped filters..the car saw different air characterisics. Tryin cleaning the MAF and TB. Clear codes and drive it for a bit. Its gonna take at least 200 miles of driving to adjust
Old Dec 14, 2009 | 06:44 AM
Conrad283's Avatar
I need a truck
This is the thread:
http://forums.maxima.org/all-motor/5...26-maxima.html
Old Dec 14, 2009 | 06:34 PM
MaxxKid's Avatar
the code is p0100 the problem came when i moved the car with the maf unpluged why you guys so hard on me i work from 5 am to pm ok i got off early today
Old Dec 14, 2009 | 06:42 PM
Conrad283's Avatar
I need a truck
Not hard on you ...
But code 0100 doesn't exist.
If you drove with the MAF unplugged. Plug it back in. Turn the car on, shut it off, unhook the battery for 10 minutes, and hook it back up. If the code is still there, reset the ECU with the screwdriver.
Old Dec 14, 2009 | 08:12 PM
MaxxKid's Avatar
P0100...
If you drove with the MAF unplugged. Plug it back in. Turn the car on, shut it off, unhook the battery for 10 minutes, and hook it back up. If the code is still there, reset the ECU with the screwdriver.[/quote]
Old Dec 15, 2009 | 10:33 PM
MaxxKid's Avatar
ok so I changed the maf now how to reset the ecu
Old Dec 15, 2009 | 11:44 PM
FallenOne's Avatar
http://www.vqpower.com/images/60k_se..._ecu_reset.jpg
Old Dec 16, 2009 | 08:58 AM
Kevlo911's Avatar
Kevlo for President
Search for 5 min next time
maxfever1987
Nov 19, 2016 08:01 PM
NewMax03
Oct 29, 2015 07:44 PM
MaximaRaj
27
Oct 2, 2015 07:31 AM
zzznightmarezz
Sep 21, 2015 06:32 PM
chernandez1278
Sep 16, 2015 01:18 PM
