A big update!!!!
Old Dec 18, 2009 | 04:05 PM
khantalha+'s Avatar
A big update!!!!
so i have been having these random misfires/backfires and hard starts for over a year now...i recently did a full 00vi swap (previously Mevi) which made it even worse...getting 14 miles to a gallon, car hesitating to accelerate, hard starts, CPS(cam) and Knock sensor and 02 sensor codes..even installed new injectors and spark plugs ...so i gave up on it and took it to my trusted mechanic...after a few hours of effing around and after 4 used CPSs we decided to buy a new one and found out it was cylinder 1 that was misfiring..we installed a new CPS and a KS. i had a couple 00vi rear coils sitting around so we pulled one out of cylinder 1 and replaced it with another used one but wrapped in electrical tape..cleaned out Crank Shaft position sensor (POS), tightened up bolts on 00vi for the vacuum leaks i had..
We started her up and bammm ... first click she fired right up.. we test drove it (did a couple WOTS) for abt good 30 miles now since this evening.. and everything seems to be fine.2 codes came back both 02 sensor codes
i dont know what was causing it but a new CPS, a cleaned CKPS (POS), and a coil wrapped in tape seems to have fixed the problem...
i am gonna keep driving this one( i have 2 maxima) for atleast a week and keep u guys updated if anything happens.
hope this all helps.
Talha
Old Dec 18, 2009 | 04:48 PM
chillin014's Avatar
Interesting that you say you were replacing the sensors with used ones, that's what I've been doing. They ohm out properly so I figure how could they ALL be bad....but my problems continue.
Old Dec 18, 2009 | 04:56 PM
khantalha+'s Avatar
yeah i even pulled one out of my other max and same thing.. i still dont understand that part
Old Dec 18, 2009 | 10:59 PM
tyler5619's Avatar
maybe it's not the part itself?
maybe a bad harness/chafed wire somewhere? just tossing ideas at you.
Old Dec 19, 2009 | 03:48 PM
khantalha+'s Avatar
yeah i dont know what exactly was it.. but car is running like a champ
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
mkaresh
Mar 12, 2018 06:48 PM
MichMaxFan
Sep 30, 2015 09:18 AM
