Oil Leak
Old Dec 3, 2001 | 11:16 PM
NISMOPower's Avatar
Oil Leak
I have a pretty bad oil leak now...Whats the easiest and fastest way to find it and fix it? Will taking it to any shops do it fast?
Old Dec 4, 2001 | 04:08 AM
Micah95GLE's Avatar
Check the oil sending unit. That might be the source of the leak. A few of us have had those things go bad.
Old Dec 4, 2001 | 10:31 AM
Max4U's Avatar
After doing that make sure the drain plug and the oil filter are ok.
Old Dec 4, 2001 | 10:35 AM
Sonic's Avatar
Wash off the entire engine bay ,then drive the car at low speeds around the block. Park it and observe where the leak is coming from.
Old Dec 4, 2001 | 01:45 PM
Str8ridin's Avatar
Also, check the plastic gasket that goes into the drainplug on the screw...sometimes it cracks etc. and promotes a small leak from there.
Old Dec 4, 2001 | 03:54 PM
WaarrEagle's Avatar
Check your oil pressure switch too. The Nissan dealer said mine was leaking oil and fixed it under warranty so I don't know much about it except it was leaking.
Old Dec 4, 2001 | 04:19 PM
NISMOPower's Avatar
How do i wash the engine bay? Hose what? What about the electronics?
Old Dec 5, 2001 | 02:16 PM
Craig K. Balgobin's Avatar
WHERE IS THE OIL SENDING UNIT
Old Dec 5, 2001 | 03:21 PM
bill99gxe's Avatar
Evil Administrator - "The Problem"
If you had followed the rules, you would know.
http://forums.maxima.org/showthread....threadid=45742
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
