Is this a normal behavior from A/C ?
Old Jan 1, 2010 | 04:15 PM
mahanddeem's Avatar
hi
Weather outside = 30F
Fan dial = on position 2
A/C button = OFF (a/c compressor is off..and no rise in idle)
Temp. setting = on middle of the red area
and the vent. openings blowing hot air after about 3-4 min driving ? (car is GXE and no auto climate control).....thanks
Old Jan 1, 2010 | 08:08 PM
1992maximase30's Avatar
if your saying that it takes about 3 or 4 minutes after you started the car up from a cold engine.
then yes.
it does take awhile for the car to warm up.
Old Jan 1, 2010 | 08:23 PM
mahanddeem's Avatar
my question was not about the car warming up,but the A/C without compressor
Old Jan 1, 2010 | 08:57 PM
well your not gonna get a/c unless the compressor's on.
try turning on your compressor you will noticed the difference if your system is charged properly
Old Jan 2, 2010 | 06:05 AM
njmaxseltd's Avatar
You don't have A/C without the compressor running, all you have is vent and heating.
Try reading your owners manual for a good description on how the system works.
The A/C will not run if the outside temps are below freezing.
Old Jan 2, 2010 | 09:47 AM
mahanddeem's Avatar
So I can get heating without the compressor running ?
Old Jan 2, 2010 | 11:49 AM
Goomz's Avatar
yes
Old Jan 2, 2010 | 01:42 PM
dan1el's Avatar
You may need to be a little more specific. If you run the heater without the compressor, it can still produce heat after the car warms up.
If you are talking about hot air while the car is moving, it could be simply that you don't have the re-circ on.
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
mclasser
Sep 24, 2015 11:57 PM
NissanNismoZ
Sep 12, 2015 07:30 AM
