B&M STS Problem
Old Jan 13, 2010 | 09:16 PM
DTrem08's Avatar
B&M STS Problem
Hello all, I recently picked up a b&m short throw from an .org member. I installed it the other day and am having a couple of odd problems.
First, when the shifter is in ANY gear, it can move 2-3 inches to the LEFT. It does not move to the right at all, which is obviously good. This makes it very difficult to tell if I'm in neutral or in gear, including reverse.
Second, the shifter can move about an inch up/down when in first and second gear ONLY. I popped off the shifter trim and took a picture and this is what it looks like when it is UP:
This shows the blue collar and the ball/plastic C bearing. The entire rod/ball/bearing move down from that position about an inch. Am I missing something there that wasn't included? The blue collar does not move.
Old Jan 14, 2010 | 05:32 AM
Nismo's Avatar
I think the problem is under the car. Check your shifter bushing and make sure its tight and also make sure the return spring is still there.
Or maybe thats why the guy sold it to you.
Old Jan 14, 2010 | 05:41 AM
Nrw's Avatar
Nrw
I wonder if the snap ring is missing or broken.
Old Jan 14, 2010 | 05:48 AM
DTrem08's Avatar
Its difficult to see in that picture, but there is a small snap ring above the ball
Old Jan 14, 2010 | 08:01 AM
DTrem08's Avatar
Also, speaking of the spring. When in gear and it the rod moves to the left, it does spring back to where it should be. Same when in neutral. Where can I pick up a replacement bushing for the B&M?
Old Jan 14, 2010 | 08:11 AM
cashoit's Avatar
yeah...the shifter should be secure. U are missing something or didnt install correctly. There is a how-to, if u wanna check
Nismo's Avatar
Go under the car and have a friend move the shifter around in and out of gear and see how it moves from under the car. You should see what is causing it to have excessive movement.
Old Jan 14, 2010 | 08:13 AM
DTrem08's Avatar
Just got off the phone with B&M and they don't have anything available for this because its been discontinued
Old Jan 14, 2010 | 08:19 AM
cashoit's Avatar
A fellow Bostonian...nice!
Im in the worcester area but in boston every wknd.
U can always go back to stock if u gotta....
Old Jan 14, 2010 | 08:56 AM
DTrem08's Avatar
Yea, but that wont help the 140 I sent to the orger
Old Jan 14, 2010 | 10:00 AM
DTrem08's Avatar
UPDATE: Heres pictures from under the car:
Old Jan 14, 2010 | 10:42 AM
wirelessdude04's Avatar
mmmm.... Mine was moving around also i retightened everything and used lock thread
Old Jan 14, 2010 | 02:30 PM
Nrw's Avatar
Nrw
Yea my next guess would be to make sure all the bolts are nice and tight. My B&M has been tight since I got it, almost 3years ago.
Old Jan 14, 2010 | 02:55 PM
DIAMONDS98SE's Avatar
I want to get one of these kits for my car. How hard was the install? Im fairly car-literate.
Old Jan 14, 2010 | 07:33 PM
DTrem08's Avatar
Thats the problem, everything is tight...
Does it look like everything is in there right? I had no instructions. I would like to get a new bushing for the bottom of the rod, does anyone know any that would fit in to it? B&M no longer has them
Old Jan 14, 2010 | 08:17 PM
Nrw's Avatar
Nrw
It's been a while since I looked at mine but it seems like it should be fine.. I can see if I can find the box it came in and take pics of the instructions and upload them if you want? That is if I still have the box.
Old Jan 15, 2010 | 06:36 AM
DTrem08's Avatar
Thanks, that would be great!
Old Jan 15, 2010 | 08:05 AM
DTrem08's Avatar
Well I just got back in from looking at it again.
I think the vertical play in it is from the rubber dust boot seen from below is installed incorrectly. I think it had so go above the black metal peice with the hole in it. Its not doing anything the way it is now so Ill give that a shot later.
I definately need a new bushing to go in the bottom of the shift rod, I think thats where my side to side play is coming from. Where can I get one that will fit in a B&M since the stock ones didnt work for me and B&M no longer makes them
Old Jan 15, 2010 | 08:12 AM
JSMax's Avatar
Sold
the b&m ones that you are talking about are a nylon bushing. it came with 4 of them. I would think that you could find 4 of them at a part store.
Also, try talking to b&m again... that shifter is the same one they use for the 240 I believe. Let me find the box and I can get the part number if that helps ya.
The part number from the b&m box is 45087. I no longer have the install instructions. Maybe someone on here can jack up their car and take an underside picture?
Old Jan 15, 2010 | 09:33 AM
DTrem08's Avatar
4 of them? The stock one only had 2...did B&M include two extra or something?
Old Jan 15, 2010 | 11:30 AM
Nrw's Avatar
Nrw
I must have tossed the box it came in all I have left is the shift ****. But yes I want to say there was 4 nylon bushings like JSMax is saying. The instructions didn't really say what to do with them so I threw all of them on, two on each side.
Old Jan 15, 2010 | 02:29 PM
DTrem08's Avatar
Were they bushings or spacers?
Old Jan 15, 2010 | 02:51 PM
ugafanz's Avatar
I was searching a while back for a STS and came across a pictorial of the install . Ill try to find that if itll help. I remember when you bought this i was gonna get it but you bet me to the punch , lol. Did you try contacting the guy you bought it from ?
**Edit***
Got it !!! Hope this will help you out. Its not a B&m though.
http://www.twmperformance.com/manual...stallation.pdf
Old Jan 15, 2010 | 06:07 PM
DTrem08's Avatar
Yea, I tried contacting him but he hasnt been on since.
EDIT: I got in touch with him tonight via PM. He had never installed it and bought it from another orger saying it was complete, but is not since there were no bushings. Im still trying to source a set of bushings that will fit the B&M
Old Jan 25, 2010 | 03:47 PM
jams's Avatar
Is this resolved yet? If not, here's what's missing: You need the bushing that fits around the bolt that connects the linkage to the lever, PLUS washers on each side of the lever along that bolt between where it attaches to the linkage rod. I used 2 on each side if I recall...
Old Jan 25, 2010 | 06:45 PM
JSMax's Avatar
Sold
two per side sounds right. I tried it with one on each side and it was pretty loose. Two snugged it right up.
litch
123
Jan 4, 2024 07:01 PM
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
zmcneely13
Sep 26, 2015 02:26 PM
