head lights are toasted, how much to replace?
Old Dec 5, 2001 | 06:20 PM
TheLza23's Avatar
For the last month or so I have had no head light and today i checked them to see what was wrong and saw that the plugs to the lights have melted because the light bulb burn to hot. So I guess I have to replace them. Has this ever happen to anyone here, I was using those Nokya's and how much does it cost to replace those tips?
Old Dec 5, 2001 | 06:38 PM
Blaximazx's Avatar
Re: head lights are toasted, how much to replace?
I guess it should cost atleast $300 which should include the tech to diagnose the problem, along w/ splicing some new headlight connectors, should be cheaper if you do it yourself and get the parts from the dealer. good luck.
Old Dec 5, 2001 | 10:28 PM
KFL's Avatar
KFL
my friend did the same thing to his older max 90 with the nokyas he upgraded the harness high wattage one roughly 60 or so at the time. No problems after that. Just get that if you want 2 run high wattage bulbs.
Old Dec 6, 2001 | 05:19 AM
amixam98's Avatar
Needs non-Maxima Friends
Cost me $70 when I toasted my harness.
Old Dec 7, 2001 | 07:22 AM
bsr1031's Avatar
I run Hiper Industries bulbs and melted a headlight socket this past summer. Just went down to AutoZone and picked up a socket for $5. Spliced it back in and haven't had a problem since. If you want to upgrade the harness you should be able to get one for around $35 or so. Check Autodynamic.com.
Old Dec 7, 2001 | 09:59 AM
hockeyghst's Avatar
yeah my drivers side headlight harness is fried but it still works....i did not think this was caused by the bulb burning to hot....do i need to buy ones that can take more power to them and if so where cna i get them.....???????????
Old Dec 7, 2001 | 04:40 PM
patel_anu's Avatar
yeahh thats wat i did, i went to autozone and paid like 3 bucks for another harness and then just rewired it, its pretty easy, theres 3 wires and just connect them....
Old Dec 7, 2001 | 11:11 PM
puremax's Avatar
how much does it cost? why is the sky blue? why is water wet?
Old Dec 7, 2001 | 11:30 PM
NYCe MaXiMa's Avatar
same question has just been asked..
look here:
http://forums.maxima.org/showthread.php?threadid=83192
Your bulbs are higher wattage then stock, if u dont want to keep burning the harness, get the upgraded one..
BTW, 70$ sounds like too much for wire harness..... I never burned mine, but i heard it costs like 6$ at pepboys, autozone etc... for stock 9004 wire harness.....
Old Dec 8, 2001 | 06:39 AM
pjalst
Same thing happened to my wife's 94 Altima. I just got two plugs from a salvage yard fo $25 for the pair( one extra plug in case I F'd it up. Connect the wires and you're driving again. Just make sure you change the healight fuse in the fuse box also, It goes when the light burns out.
Justinmc760
Aug 23, 2015 03:10 AM
doobadoo
Aug 15, 2015 06:43 PM
Samedi
Aug 12, 2015 01:54 AM
MikesChevelle
Aug 6, 2015 11:36 AM
