i got a question about the intake manifold
Old Feb 2, 2010 | 04:48 PM
maxxx25's Avatar
Okay i have been having problem's with the check engine it keeps throwin an egr code .... well i took it to the mechanie and i bought the new egr and when he was gonna replace it he said it wouldn't work cause my car didn't have the egr lines well years ago i replaced the motor and i think i have a 99 motor in it so now i have to get a new manifold anybody got any idea where i can get that line... i think am missin the line the real small one i think its a 10mm
Old Feb 2, 2010 | 05:08 PM
cartman854's Avatar
Old Feb 2, 2010 | 05:28 PM
smai555's Avatar
check the for sale section there are a few people that are parting out the car you just need a pic of the part you need ... you can also try a guy named joe i dont remember that is name on here is i i think its maximajoe
Old Feb 2, 2010 | 08:02 PM
Fasteddie01's Avatar
Look it up here : http://nissan4u.com/parts/maxima/
Old Feb 2, 2010 | 08:23 PM
FallenOne's Avatar
wow, awesome thread... why not try searching first? first off; if you swapped an engine from a 99 did you also swap the ECU or are you still running your older ECU? cause quite honestly had you searched you'd know you dont even need your egr; and that you can simply block it off and let the sensor dangle...
/thread
Old Feb 4, 2010 | 04:44 PM
maxxx25's Avatar
yea i have the same ECU... so how do i elimite the egr and wont the check engine light stay on?
Old Feb 4, 2010 | 09:04 PM
FallenOne's Avatar
do a quick search and youll find the answer you seek; you need to block off the EGR passage ways, one on the Header and the other on the UIM and just let the Sensor dangle...
Old Feb 5, 2010 | 08:19 PM
mrfliboi's Avatar
i dont kno if this helps. but wen u get ur system. and ur po400 egr code dont go away try this
http://forums.maxima.org/4th-generat...ing-p0400.html
Maxboy23
Sep 9, 2015 10:37 AM
Maxboy23
Sep 4, 2015 06:04 PM
lux97Max
Sep 4, 2015 05:42 PM
