Need help identifying this...
Old Feb 4, 2010 | 02:01 PM
aaronleong's Avatar
Sorry no picture, but when I removed the IACV valve assy to clean, I see through the opening that there's a hole/indent on the bottom of what I think is the main air flow chamber. What is that? Is it the EGR tube inlet?
As far as I can tell, that hole/indent in my car is clogged. Is there a way to clean it from there? Or is there a solvent/cleaner I can safely use?
Old Feb 4, 2010 | 02:56 PM
M in KC's Avatar
You need to clean the carbon out of there. This is where the exhaust gas gets introduced into the plenum. Napa makes a product called Macs throttle body and choke cleaner but any throttle body choke/carb spray should be fine. Its tough spot to clean.
Old Feb 4, 2010 | 02:59 PM
aaronleong's Avatar
Maybe that's why my car has been dying under braking. That area in mention is darned clogged. Anybody has any creative ideas that they've used to clean this inlet?
Old Feb 4, 2010 | 07:58 PM
nhaven's Avatar
If that hole/passage is clogged, then your egr tube is most likely clogged as well. You need to remove the egr tube to clean it.
D Mason
Jun 21, 2016 04:43 AM
follyburr
Detailing
Jun 13, 2016 02:06 PM
followthadollar
Sep 13, 2015 09:55 AM
0m3nc0w
Sep 11, 2015 05:21 PM
Colossus
Sep 9, 2015 05:46 AM
