vibration in the steering under load
Old Feb 12, 2010 | 09:35 PM
maxima1380's Avatar
I have a 99 SE-L auto. Anytime you take off half throttle or more there is a vibration in the steering wheel, also some light torque steer to the right.
On the other hand when you are cruising down the road at highway speed. The vibration isn't there until the car is under a certain amount of load. If I use the cruise control it is almost non existent. Any help is appreciated and thanks in advance.
Old Feb 12, 2010 | 10:13 PM
IlyaK's Avatar
The Golden One
Does your check engine light blink when you do this?
Sounds like a misfire to me. They are sometimes more noticeable when you get on it. You may have a problem creeping up on you. 99's are common for coilpack issues. I'm also a 99 and have replaced all my coils with 98 or older.
Old Feb 12, 2010 | 10:59 PM
Snypa's Avatar
^why 98 or older.? Im 99 too+cali spec...and i havent done coils since i got the car. My main problem so far though is it doesnt start smooth.While cranking(starter sound), its as if it gets interupted and then jerks/jump/skips at start. Happens most time when car been sitting for a long time.
Old Feb 13, 2010 | 08:13 AM
njmaxseltd's Avatar
Sounds like a misfire. See if you can pull any codes from the ECU.
Old Feb 13, 2010 | 09:15 PM
maxima1380's Avatar
I was thinking more of a front end issue. The car doesn't hesitate or have any other issues while parked with no load on the engine. The car starts and revs up normal. I was thinking maybe a sway bar bushing issue or maybe a tie rod end. The ecu doesn't have any code either.
Old Feb 13, 2010 | 10:26 PM
IlyaK's Avatar
The Golden One
So? That doesn't mean anything. Search coilpacks and you'll see HUNDREDS of threads about it and how to test to see if it's the packs.
If it was your front end, it would depend on speed, not load. You could be 100% WOT at 10mph and have the issue and also 100% WOT at 60 and have the issue. or you could be doing 10 or 60mph without 'load' and not have the issue.
It's your coilpacks most likely.
It's a common issue on 99's. VERY common. I've been through three sets until I specifically bought 98 or older packs.
Old Feb 16, 2010 | 07:19 PM
maxima1380's Avatar
I got the ecu checked again today. It has three different codes for the bank 2 o2 sensor. No other codes. Is it possible that the bad o2 sensor is causing the issue?
Old Feb 16, 2010 | 07:26 PM
JNCoRacer's Avatar
Just the tip.
Mine was doing this a couple summers ago. Turned out that my passenger side axle was out of balance.
Old Feb 16, 2010 | 08:03 PM
L2theBR's Avatar
On a scale of 1-10 how bad is the vibration? Like is it a bad jerking vibration that you can feel throughout the car, or just a slight vibration that you can only feel in the steering wheel?
Old Feb 17, 2010 | 12:02 PM
cashoit's Avatar
take it to a mechanic man....we jus grasping at straws unless u got a code or can be more specific
Old Feb 17, 2010 | 06:46 PM
maxima1380's Avatar
That's what a friend of mine said it could be, after he rode in the car. The axle is fairly cheap so I will replace that and see what happens. Thanks for the feed back fella's
jmlee44
Oct 2, 2022 02:13 PM
user 11122324
42
Jul 18, 2022 03:35 PM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
