Help! Bald Fuel Injector Screw :-(
Old Feb 17, 2010 | 04:54 PM
Dexter's Avatar
Hi guys, I'm in the process of replacing my cylinder 3 fuel injector, I already got the UIM off (thanks to the helpful writeup written by ATTappman) and managed to get one of the fuel injector screws off, but the other one is severely bald and even with a screw remover it seems to only be getting worse. I tried ratcheting it out with the screw remover while putting downward pressure on it but no luck. I will try using a power-drill to drill it out, can anyone offer any further suggestions?
I think I'm gonna call it a day here though. I will keep working on it tomorrow or sometime on the weekend. Can't wait to get my MAX back on the road.
Old Feb 17, 2010 | 06:10 PM
HandsonMaxima.'s Avatar
i use vice grips on all those soft bolts and replace them, after my 00vi swap i have maybe 1/3 original bolts that i started with.
Old Feb 17, 2010 | 06:26 PM
Dexter's Avatar
Problem is it's not a bolt, it's a screw. Will that really work on a screw?
Old Feb 17, 2010 | 07:50 PM
hornepirate's Avatar
yes...thats exactly what i used on mine
Old Feb 17, 2010 | 08:32 PM
screw/bolts=same thing to a pair of vice grips
Old Feb 18, 2010 | 01:10 AM
Dexter's Avatar
Ok, I will try that if the power drill doesn't work. Thanks
Old Feb 21, 2010 | 10:12 AM
Dexter's Avatar
Update!
Finally got that f*cking screw off
The drill/screw remover didn't work for sh*t, all it did was strip the screw even more. So I used some vice grips (thanks for the suggestion guys)
Once those screws were off I replaced them with a pair of 8mm bolts (let's see that try and get stripped!).
Then I moved on to remove the fuel injector with the vice grips it actually came out a lot easier than I expected just grabbed it by the head and pulled it straight up.
I will replace the gaskets and put the Max back together tomorrow
Thanks for all the help guys.
Old Feb 21, 2010 | 10:23 AM
bryan163's Avatar
Next time try an impact drive. You place a phillips bit in the chuck and strike the back with a hammer. It rotates as you strike it. Works amazing on stuck fuel injector screws.
I've done the vice grip thing to, but this works much better and never damages the screws.
Old Feb 21, 2010 | 05:55 PM
hmm, i like that impact drive, how much do those go for?
ill also need a buy a hammer...
Old Feb 21, 2010 | 07:24 PM
bryan163's Avatar
$5.99 from Harbor Freight.
http://www.harborfreight.com/cpi/cta...emnumber=93481
And if you cant find a hammer, just smash it with a rock.
Old Feb 21, 2010 | 11:25 PM
Dexter's Avatar
Old Feb 22, 2010 | 06:39 AM
This is what mine looked like for my injectors...The metal was so soft that i could use a Phillips head screw driver and a rubber mallet and hammer in new grooves for the head. I got tired of trying to get it loose and just got my vice grips...put'em on tight and gave it a good twist
Old Feb 22, 2010 | 08:06 AM
luke95gxe's Avatar
needle nose vise grips work well
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Forge277
Jun 13, 2016 09:26 PM
doctorpullit
Mar 29, 2016 11:08 AM
