My max is going crazy!! Help!!!
I just did my conversion from auto to 5 speed, and usually when i stop at the light, the rpm would drop to my regular idle speed after about 2 seconds, which is about 800. now it will stay at the around 1500 and then finally if i get lucky..it'll drop down to 1100. while this is happening... my temperature gauge would go wild...it'll start jumping up
and all the lights in my car would start dimming. anyone have any idea or suggestions???
Yeah, i commend you for doing the 5speed conversion man, that's really cool, i'm also sorry things aren't going quite as planned, but seriously, you don't need to post more than one thread about the exact same damn thing withing like ten minutes of each other.
damn it!!
grrrr...this damn board is always busy..and i didn't even know i posted so many damn posts grrrrr... the conversion was very successful, but i have no idea what's going on right now...it's really weird.... i been driving the car for about a month and..and today was the first day it happened...and all i did is change out the struts and change the air filter.
Re: damn it!!
grrr...
this is not about the conversion...after the conversion..my car ran fine!!!! but i was working on it today again..maybe i shorted something... someone told me it's the negative on my battery. so i am going to give that a try
Re: grrr...
thats why im saying reset the ECU... air filter, or the sensors around it have made my car run poorly, resetting just let it read just its idle and whatnot. its worth a try.. it has fixed a problem or two for me before. i doubt it involves the swap, just the idle levels..
Re: grrr...
Re: i'll give that a try
hehe..thanks man.i'll give that a try...but about that lights dimming in and out..tha'ts just plan crazy!
Re: Re: i'll give that a try
Originally posted by Mishmosh
Your alternator may be going. Get it checked...
SuDZ
thanks!
thanks you all =) my call kinda just died on me today, and my dad jumped the car for me, and it worked again...i think my battery is bad, and so i just went and got a new battery, and now everything is fine again =) thanks you all again!!
Steve
Steve
Re: thanks!
No... Your alternator is probably dead.. Turn your car on and disconnect your negative lead.. If your car dies then bad alternator.. Bad batteries prevent starting.. If you have a bad alternator then your car will die while running..
Re: Re: thanks!
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
magiconthetire
Oct 26, 2015 09:03 PM
