Fun worthless facts: Weight Stock Cali spec to Warpspeed y + fed front manifold
Old Feb 17, 2010 | 07:49 PM
EsQueue's Avatar
I started to install my fed spec Warpspeed y and Fed front manifold and decided to get a weight difference from a bathroom scale.
The Cali spec front pre-cat and front manifold are nearly inseparable so I weighed that first.
Cali pre-cat & front exhaust manifold 21.6 lbs.
Rest of Cali spec y pipe 16.6 lbs
Total Cali spec y pipe + manifold 38.2 lbs
Fed spec front manifold 8.0 lbs
Fed spec Warpspeed y pipe 10.8 lbs
Total Fed spec y pipe + manifold 18.8 lbs
That is a 19.4 lbs savings in weight. LOL, the cali front precat and manifold weighs more than the entire fed spec setup.
Old Feb 17, 2010 | 08:01 PM
clint240sx's Avatar
weight reduction ftw!
Old Feb 17, 2010 | 08:13 PM
Quickywd01's Avatar
I've got a cali. spec with WSP y-pipe. Good to know. Did you use a 02 sim for the front?
Old Feb 17, 2010 | 08:29 PM
EsQueue's Avatar
I'm using the antifouler trick. Need to extend the sensors though. I will give results as soon as I complete tomorrow. Did you keep your front pre-cat?
Old Feb 17, 2010 | 08:59 PM
Quickywd01's Avatar
Nice. Yep I still have my front pre-cat. But I will be putting on my sc in the summer so I'm interested in removing the pre-cat since I know what they do on a sc car. My friends supercharged toyota was cali spec and he lost 100whp on the dyno and they smelled so bad, they got cooked to a crisp.
Old Feb 17, 2010 | 09:09 PM
EsQueue's Avatar
Wow, I'll have to search this up. I already have my supercharger but I haven't installed it yet.
The installer recomended that I had some sort of afc (done), Transmission cooler (purchased), shift kit (purchased) and fed spec conversion with a y pipe (almost done) before he installs the SC. I am surprised on the honesty instead of rushing for a quick buck and then tell me after everything is installed.
Old Feb 18, 2010 | 06:20 AM
cashoit's Avatar
hmmmm or maybe its my 80 lb tool kit and 40 lb sub in the trunk lol
Old Feb 18, 2010 | 07:58 AM
Quickywd01's Avatar
Should have searched on here. I'll be using at least the DR mod instead of the VB mod or shift kit. What kind of afc? But sounds like you have a good person helping you out.
Old Feb 18, 2010 | 08:29 AM
EsQueue's Avatar
I was excited about getting the sc kit and would have installed then upgraded but he insisted that I wouldn't be able to resist pushing it and would probably delay the recomended items
I got a vafc 2 if I ever decide to install an 00vi kit.
vingodine
45
May 21, 2016 12:46 PM
melteye
May 16, 2016 12:02 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
george__
Aug 18, 2015 07:06 PM
1992maximase30
Aug 5, 2015 09:27 PM
