Just need a little advice
Old Feb 20, 2010 | 01:56 PM
brasso's Avatar
I did some work to my car in the last 5 months. I haven't started it at all in this time. Is there anything i should do before starting it up? The reason i ask is because i have read on here about the timming chain tensioner lossening and the chain jumping a tooth.
Any advice would be great
Old Feb 20, 2010 | 03:42 PM
nitromax's Avatar
just to be on the safe side of things--remove all spark plugs and fuel pump fuse. that will remove any load/resistance to the starter, while you crank it over to build oil pressure back into the system and relube everything internally. 2 or 3 20 second cranks should "gitter done". reinstall plugs & fuse and start as usual. or just start w/o all the fanfare, it'll be fine!!!
Old Feb 20, 2010 | 05:08 PM
brasso's Avatar
thanks for the help!! I just crossed my fingers and started it. Everything went fine.
Mahmuth
Aug 16, 2024 08:23 PM
gigabyte
Jan 6, 2017 06:05 PM
Pnjboyzz
Nov 16, 2015 12:27 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
dshinn
Sep 26, 2015 08:07 PM
