Possible to hit 200 whp w/o 00VI?
Old Feb 21, 2010 | 07:24 PM
L2theBR's Avatar
Just wondering if anyone was able to hit a max WHP of 200+ w/o an 00VI/MEVI or FI on an automatic 4th gen max? And if so with what mods?
Old Feb 21, 2010 | 08:03 PM
Snypa's Avatar
These are what people normally do......intake, pulley,flywheel,y-pipe,headers ???
Old Feb 21, 2010 | 08:17 PM
xkazik's Avatar
What pulley gives u hp?
Old Feb 21, 2010 | 08:22 PM
Tatanko's Avatar
Bacon Lover
A lightweight and/or underdrive one.
To the OP: it's possible, but not cost efficient.
Old Feb 21, 2010 | 08:24 PM
xkazik's Avatar
O i will research this as well never new they give hp .so thats what they exactly call?
Old Feb 21, 2010 | 08:36 PM
JAMAICANLOVRBOY's Avatar
its very possible, i had 198whp with a DE motor, all i had was I/H/E y-pipe, SAFCII. the dyno was done on a dynojet.with UD pulley, 3" catback, and cat delete, i wouldve been over 200whp
Old Feb 21, 2010 | 09:23 PM
nismomaxgtr18's Avatar
I think its possible. I dyno'd 181 whp with just intake, ypipe, hi flow cat and exhaust with a regular DE motor and autotragic transmission and that was on a Dyno Dynamics machine which supposedly reads lower than a Dynojet.
Old Feb 21, 2010 | 11:54 PM
aackshun's Avatar
Damn... I need to get on a Dyno then, I'm sure I'm around 180...
But to the OP, I'm sure you can plop in VQ35 cams and intake spacers (plus all of the aforementioned bolt ons), you'll be close enough to 200whp.
Old Feb 22, 2010 | 04:50 AM
Flava_24/7's Avatar
Boosted Panda
Man, you guys put down some good numbers.
Back when I was still NA I put down 177 with I/Y pipe/Exhaust/straight pipe/MEVI/JWT ECU/UR UDP/Stillen Flywheel
Old Feb 22, 2010 | 05:01 AM
Redline Maxima's Avatar
i did 179whp/183wtq with intake, headers, y-pipe, catback, fidanza flywheel. it was over 95 degrees that day though and then engine was heat soaked. i have yet to go back and dyno with the 00vi and JWT ECU
Old Feb 22, 2010 | 07:00 AM
cashoit's Avatar
well, consumerguide.com has the 4th gen at 190 HP stock. How are ppl dynoing lower than that?? O ok... i think i jus answered my own question. The 190 HP is prolly jus the engine without the tranny hooked up to it. THere are losses with the tranny so the whp is prolly 170 ish.
Old Feb 22, 2010 | 08:10 AM
L2theBR's Avatar
the 190 hp that the engine is rated at is just engine power, stock our cars are about 135-150 at WHP
Old Feb 22, 2010 | 08:14 AM
lmfaoooo....190 hp is at the crank. Realistically, a stock 4th gen would put down 150-165 hp at the wheels.
Old Feb 22, 2010 | 08:19 AM
cashoit's Avatar
Ouch man, why the backsmack lol
135 ish huh, thats pretty low. I was being generous with the 170 whp suggestion, since a quick google search didnt yield any numbers.
that being sd, 200 whp with no 00VI or F/I would be difficult. I think with intake, exhaust, and weight reduction mods you cd do it. but nothing much higher.
With the 00VI its def possible.
Old Feb 22, 2010 | 08:29 AM
cashoit's Avatar
ANd im still lookin for those Mass Maxi Meets...WTF!!!!
Old Feb 22, 2010 | 10:45 AM
Tatanko's Avatar
Bacon Lover
But it's not. I dyno'd 170 WHP with basically just a y-pipe on my current 5-speed car, and that was a dyno that reads really low compared to the "standard" (i.e. Dynojet).
Old Feb 22, 2010 | 11:55 AM
aackshun's Avatar
That's actually low for all of that stuff, I'd expect you to be near 200 w/ all of that....
You have the same username on Youtube right? If so I love your exhaust setup, that's exactly what I wanna do.
Old Feb 22, 2010 | 12:03 PM
cashoit's Avatar
O yeah, its not impossible. But i thingk its highly unlikely.
By hard i meant u wd need a lot of mods...well lets look at these quantitatively,
1) short ram intake.....5-10 hp
2)y pipe....5-10 hp
3) hi-flow cat...5-10 hp
4) catback 2.5 exhaust w/ hi flow muffler.....10-15 hp
5) UP.......5-12 HP
6) fidanza flywheel ......5-7 HP
(Anyone have objections to these numbers???)
on the low side, that adds up to 35 extra HP...which would prolly get you to 180+ whp
on the high side,,, that adds up to about 50 HP....that gets u to 190+ extra HP.
Like i sd, you could get there but it would be difficult and require other weight reduction mods. U prolly top out at 200 WHP. Nothing more.
THats why ppl do the 00VI mod, cuz its a 15-25 HP increase. With all the other mods included u would def get u to 200 WHP
Old Feb 22, 2010 | 12:05 PM
cashoit's Avatar
haha.."back when i was still NA" ...nice!
Old Feb 22, 2010 | 12:11 PM
Nealoc187's Avatar
SLOW
probably a little bit of a stretch for an auto to make to 200whp but some dynos read high so you might get a sheet that says 200whp. whether or not you'd be faster than the guy next to you with a sheet that reads 185whp from a different dyno is a whole different question...
this is why dyno numbers mean nothing when you're comparing such small variances like 10whp here, 10whp there.
Old Feb 22, 2010 | 01:19 PM
Snypa's Avatar
I am terrified to put my car on a dyno. I might cry in a corner after seeing the numbers.
Old Feb 22, 2010 | 01:35 PM
modenaf1's Avatar
2)y pipe....5-10 hp
5) UP.......5-12 HP
Hmm, I dunno about some of those numbers. If I'm not mistaken, going short ram is really only good for sound. I thought you lost power with a short ram because the factory intake isn't that restrictive and it takes in cold air. Not to mention the airflow over the MAF is disrupted with the filter being so close.
Based off my understanding, I could be completely wrong but I thought it was more like:
1) short ram intake..... negative 3-0 hp (due to heat and flow over the maf)
2)y pipe....10-18 hp (I thought the y-pipe easily added well over 10hp?)
3) hi-flow cat...0-5 hp (factory cat flows about the same as a high flow I thought?)
4) catback 2.5 exhaust w/ hi flow muffler.....5-10 hp
5) UP.......5-12 HP
6) fidanza flywheel ......5-12 HP
The last two of course having more benefits in the lower gears. I thought the factory cat was a high flow cat as is? I remember there being some debate on the actual gains had by replacing the stock cat.
Old Feb 22, 2010 | 01:56 PM
Feldman's Avatar
5) UP.......5-12 HP
These numbers are much closer
I think the short ram adds like 2-3 hp up top but you lose a bunch of torque in the middle and down low.
I also dont think you gain hp from UP and flywheel on a dyno. Your car still makes the same power but it has less weight to get moving meaning it revs quicker. Its the same idea as taking stuff out of your car and making it lighter. It makes your car faster but doesnt increase your HP.
Old Feb 22, 2010 | 02:07 PM
Flava_24/7's Avatar
Boosted Panda
Yeah, I kind of thought so too, but I hit those numbers another time I dynoed, same dyno too.
5) UP.......5-12 HP
I dont see how a Hi flow cat could give you higher gains then a straight pipe and those have shown to give us 1-2hp...
I also dont think a UDP and flywheel will free up 24whp.
Old Feb 22, 2010 | 03:03 PM
aackshun's Avatar
1) short ram intake..... negative 3-0 hp, sounds like 10-15hp.
2)y pipe....10-20hp
3) hi-flow cat...0-5 hp near red line, not overall
5) UP....... feels like 5-12 HP
6) fidanza flywheel ...... feels like 5-12 HP
I made my edits.
IMO 5 and 6 don't add HP/TQ benefits to your car. it's just not dyno reputable, more like 1/8th time reputable. This isn't Forza Motorsport or Gran Turismo folks.
Maybe your 96 ecu doesn't like all of those goodies, bad ks, bad dyno... so many variables when it comes to dynoing, which is why I really don't like it (or haven't even done it for that matter).
Old Feb 22, 2010 | 03:12 PM
Flava_24/7's Avatar
Boosted Panda
I made my edits.
The ECU was a JWT ecu, and the KS is the same one Im currently using . Its never given me any issues. IDK, car still pulled really well and spanked many on the streets.
Mods effect cars differently and results will always vary.
That dyno was the same dyno I hit 302whp on after installing the SCer.
Old Feb 22, 2010 | 03:16 PM
A-BOY's Avatar
how 00VI mod work
Old Feb 22, 2010 | 04:00 PM
Feldman's Avatar
Originally Posted by A-BOY
how 00VI mod work
00VI=2000 variable intake
It essentially involves replacing your intake manifold with one from a 00 or 01.
The 00VI incorporates a plastic manifold which keeps it cooler and dual length runners that swap over at 5000 rpm freeing up more top end power
Old Feb 22, 2010 | 04:03 PM
Yep thats me. Thanks. I just got back from a dyno today with my brother's car. I should have that up there by later tonight. Its not related to this thread but it did 366whp/362wtq lexus SC300, and it is an auto, lol
Old Feb 22, 2010 | 05:53 PM
L2theBR's Avatar
Correct me if I'm wrong, but I was under the assumption that automatics don't have flywheels, they have torque converters......
Old Feb 22, 2010 | 06:12 PM
what mods?
Old Feb 22, 2010 | 07:32 PM
shadyonedeath's Avatar
i smell bs here if ur auto and making over 200. Im 00vi/y/catback/VAFC-II tuned and i doubt im making 200+.
Old Feb 22, 2010 | 08:11 PM
93altima's Avatar
Turbo 4th Gen
1. Equal length Headers and ypipe
2. 2.5-3in full exhaust
3. Ightweight pullys
4. JWt Ecu/ EU
Total: If you install and source out parts yourself $800-$1000
FYI underdrive pully and lightweight flywheel dosent "add" hp it frees up lost hp due to drivetrain loss and etc.
Old Feb 22, 2010 | 08:14 PM
93altima's Avatar
Turbo 4th Gen
^^this guy dosent know what he's talking about
Old Feb 22, 2010 | 08:48 PM
Go dyno your car and report back the results please.
Old Feb 22, 2010 | 09:39 PM
cartman854's Avatar
5) UP.......5-12 HP
I added the short ram intake, and it doesnt seem to get to much hot air because I left the stock snorkel thing on underneath it, and when my car gets hot, the massive fans kick on and it cools fast, I found that out by letting it idle and poping the hood and feeling the air coming into the intake. Def not extremly hot air for sure, and it sucks so much air, it prob sucks the hot air quickly and then only sucks cold air.
Old Feb 22, 2010 | 10:03 PM
modenaf1's Avatar
Yea, I definitely agree with everyone on 5 and 6. I haven't done either yet, but the difference as speeds increase diminishes. All those do is allow the engine to speed up and slow down faster. Great for a first gear pull where the engine is much more limited by the amount of weight it has to spin up from 2000 RPM to 6500 RPM extremely quickly.
In 5th gear the engine can't accelerate RPM nearly as quickly thus making the reduced weight of the flywheel/pulley insignificant. Normally you dyno the car in 3rd or 4th anyway, so gains shouldn't really show up on the dyno.
Old Feb 22, 2010 | 10:43 PM
mpvibes's Avatar
I BELIEVE IT IS POSSIBLE
Old Feb 22, 2010 | 10:48 PM
aackshun's Avatar
This thread has now boarded the Failplane.
Old Feb 22, 2010 | 11:02 PM
LOL...Any reasons in particular?
Don't you mean Failboat? lol
