transmission slipping
Old Mar 7, 2010 | 10:08 AM
97MaximaPapi's Avatar
i have a 99 i30t and especially when the car is cold, the transmission doesn't catch first gear (like it's idling in neut.) when i come up to a stop sign or a light. this is frustrating as even after the car has warmed up it happens occascionally. Could this be a sign of transmission problems? It's had a tune up already and trans oil flushed about 15k ago. it only has 117k. Any idea what the problem could be?
no engine lights are on either.
Old Mar 7, 2010 | 10:19 AM
B_Eaze's Avatar
what kinda flush did you do? was it a regular drain and refill?
Old Mar 7, 2010 | 05:28 PM
Fasteddie01's Avatar
Have you checked fluid level, color and smell? Like B'Eaze asked, was your change a refill or a pressure flush done at a garage? Pressure flush can loosen debris from case and pan and it can get into valves of trans. Have you checked the FSM p. AT-74-76? This is a list of problems with prioritized causes. If you haven't d-loaded the FSM, there's a good reason.
Old Mar 8, 2010 | 07:28 AM
cashoit's Avatar
what kind of fluid did u use? sounds like its not locking into first...sounds mechanical
Old Mar 8, 2010 | 08:08 AM
mahanddeem's Avatar
OP don't do flush on a high milage AT,too much headache you might encounter...as others said,check the fluid level and quality,do simple drain and refill,note the amount drained if it's correct to refill with exactly the same amount ... use Amosil fluid....oh and clean the pan magnets
Old Mar 8, 2010 | 10:10 AM
wxm's Avatar
wxm
on fluid level. It happened to me too when the mechanic had overfilled the fluid.
Old Mar 8, 2010 | 10:30 AM
Webhead's Avatar
I have the same issue my car has to warm up, then the shift my be correct, if not, the car RPMs go high then shift after I let off the gas.
Old Mar 8, 2010 | 10:38 AM
Webhead's Avatar
what type of fluid is needed?
Old Mar 8, 2010 | 11:35 AM
B_Eaze's Avatar
Please stop double posting, u can edit ur post. The kind of fluid u need is in ur owners manual, do some research, its pretty easy to find
user 11122324
42
Jul 18, 2022 03:35 PM
Pied
Sep 26, 2015 03:29 PM
