Help Please Black grease all in my wheel well and inside my wheel??
Old Mar 6, 2010 | 09:48 PM
95Maxi's Avatar
I just replaced my axles and suspension like weeks ago, and today at the car wash I noticed grease on my drivers side front rim, so I looked further and noticed tons of grease in the wheel well and inside my rim which is really odd. The boot doesnt appear to be ripped or anything and I also noticed that my drivers side starts shaking a lil when I start taking off and gets worse between 20 and 30 miles an hour after 30 its smooth .. no noises or any other symptoms ...
not sure if this could be my wheel bearings or is this grease seeping thru the boot???
Old Mar 7, 2010 | 02:29 AM
antti's Avatar
The grease is most likely from the boot.There is no other place for that kind of thing to come. You might also need to replace it as it has started to give you shakes and you have driven it. They dont take that much driving without grease.
Old Mar 7, 2010 | 04:30 AM
ajm8127's Avatar
The CV boot has to be ripped somewhere. Thats the only place that much grease can come from. Jack up the car and rotate the hub in question, looking for a split in the boot.
Old Mar 7, 2010 | 06:10 AM
Zero Deuce SE's Avatar
What they said. That grease had to be flung from your CV axle. That's why you have the shaking. You should be able to tell where the split is by where the grease hit the fender liner.
Old Mar 7, 2010 | 07:37 AM
edwardh1's Avatar
My new Napa boots came loose (no tears) on the inboard end, garage did it over free
Old Mar 7, 2010 | 07:46 AM
Good to hear that.
Old Mar 7, 2010 | 08:44 AM
95Maxi's Avatar
Thanks guys , I just can't believe that .... It just sucks having to do this work again...
Old Mar 7, 2010 | 08:47 AM
Did you locate your problem?
Old Mar 7, 2010 | 09:28 AM
Conrad283's Avatar
I need a truck
In the 3 minutes since the his last post, probably not.
Did you do the work yourself and notice the grease when you were there?
I had this happen to me too and it was as a result of the boot being ripped.
Old Mar 7, 2010 | 08:52 PM
95Maxi's Avatar
Well i have had someone tell me that "clamp is loose " I say that cause thats what I was told so appearantly when I turn its spitting out ... well I really wished that this wasnt the issue but thank god I can return it and get a new one .. however last time I did change the axle I lost alot of tranny fluid ... what type of tranny fluid should I buy , its a 95 SE 5 speed w/abs no limited slip, If that matters??
Old Mar 7, 2010 | 10:34 PM
aackshun's Avatar
http://forums.maxima.org/fluids-lubr...-gear-oil.html
Familiarize yourself with the forum, that's a sticky in the Fluids and Lubricants section.
Old Mar 8, 2010 | 12:00 PM
95Maxi's Avatar
matts95max
Apr 23, 2025 10:44 AM
Dennis Twohy
Oct 1, 2015 06:01 PM
doctorpullit
Sep 10, 2015 06:33 PM
dcardello
Sep 3, 2015 11:44 PM
Hailstatejig
Sep 2, 2015 06:52 AM
