my retrofit light output
IIRC you only use two washers on the lower bowl of the projector. It's supposed to slightly change the focal point (or something like that) of the lens and it results in more colour being displayed at the top of the cut off.
But, you loose out on some of the sharpness of the cutoff because the lens is now further away from the bowl of the projector.
oo that's what it is. ok good we got that cleared up. yeah I was thinking about doing it...but I didn't get a chance experiment with it. I was itching to get this project finished asap. but now that the excitement has settled in I'll probably take everything apart again. as it is I have some fine adjusting to do so I'll probably experiment with the washers. what's the best way to start? just by putting 1 washer on each screw and taking it from there?
I did about a millimeter washer on all 3 mounting screws between the shield and the lens holder.
Play with it. There are a fair amount of adjustments that can be done. Works best if you hack up an old computer power supply, or a spare battery, or one of those jump-starter things so that you can test the adjustments with it off of the car
Beautiful, i love the Max looks very clean. Also gives me a few Ideas for my Retro :X
Have any authoritys ever given you any grief about the Blue Side Marker Lights? im thinking i would liek to make mine look like one piece and match my headlights.
Not including my pre-existing HID kit, which cost $60, and including shipping, the list goes as follows:
$40......Acura MDX projectors
$16......H11 4300k bulbs
$31......E55 shrouds
$12......Relay harness
$10......misc. items such as lens cleaner, sandpaper, etc.
=$109 total.
fastcarny
Oct 6, 2015 10:42 AM
Dennis Twohy
Oct 1, 2015 06:01 PM
carid
Sep 9, 2015 05:06 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
