What brake pads are you using?
Well I'm due for a brake pad change and was wonder what you guys use nowadays. I used to have a set that was really dustly. What I got now is not nearly as dusty, but they have no...bite I guess you would say. Really had to hit the brakes hard this winter, like a wood on metal kind of feel. Would gladly trade low dust for bite.
I'm currently looking at:
[41000K] FRONT BRAKE PAD SET
Hitachis OEs
Performance Friction, Z-Rated
The slots in pads of the 1st link would result in greater bite than those in the 2nd link, right? I saw the Performance Friction Z-Rated recommended somewhere, but there was no elaboration. Thoughts? FrozenRotors also has the non-Z for <$60.
Hitachis OEs
Hitachis OEs
Hitachis OEs
I however almost always use Performance Friction Carbon Metallic - (The Z rated is 'new' and I've not needed brakes since those came out, may try them on the Maxima).
I can say on the 280ZX and the 280ZXt they stopped better than stock, they don't create as much 'black dust' on the wheels as other brands, and I've never had a pad failure (ie pad disconnecting from it's backing plate).
Just my 2 cents on brakes.
oh, one more thing - they do make them for Brembo and other major 'aftermarket' brands of 'rotor / caliper combination.
FYI - the Frozen Rotor site doesn't seem to list many pads - and I know they make them for a lot more models than they show - ie my 88 200SX (CA20e/5MT/RWD) had them, and I had front and rear rotors...
Are you referring to the first link or the second? There seems to be a difference between the two (the Hitachis lack that center groove).
Good point on the z-rated being a no go, requiring warmup et al. I heard you can get Performance Frictions at autozone so I'm going to see if I can get the 'carbon metallic' locally and utilize the lifetime warranty (still can't believe they do that).
It's seems like I just had the pads replaced. I want to say the car originals lasted me until past 60k, so my current ones lasted 20-30k (I'm at 90k).
The Hawk HPS -- what kind of lifespan are you guys getting with these?
Stock 07-08 Altima pads Nissan has a TSB for brake noise and it replaces the pads and hardware so i now have an unlimited supply of "stock" pads with less then 10k miles on them.They are the same pad as a stock 4th gen pad.
With so many i have done i have a bucket at the house full of nothing but pads/hardware where i've swapped them out.
![Smilie](https://maxima.org/forums/images/smilies/smile.gif)
![laugh](https://maxima.org/forums/images/smilies/laugh.gif)
I know that they were on the car before I got them, and I did some pretty aggressive driving (and braking) in the 45-50K miles since I have bought the car, so I would say that they have a pretty darn good lifespan.
They are a little pricey though, the fronts retail for $82 and the rears are $72, respectively. Worth it to me though.
With so many i have done i have a bucket at the house full of nothing but pads/hardware where i've swapped them out.![Smilie](https://maxima.org/forums/images/smilies/smile.gif)
I am in the same boat. I have Brembo Blanks front & rear sitting in my garage. Looking for pads now. I pm'd a few senior veterans on the forum about their opinions. Still need to decide between the following:
1. Centric Posi-Quiet Ceramic Pads With Shims
2. Satisfied GranSport GS6 Carbon Ceramic Pads
3. Akebono Street Ceramic Performing Pads
4. Wagner QC537 ThermoQuiet Ceramic Pads
glad to see nobody's recommending ebc red stuff which i currently have. track pads, noise is ok, but dust is crazy, wheels are black every day. here's the problem, they're performance pads and my brembo rotors are warping with black heat spots and i do drive aggresively. when i slow to a stop, they dont grab smoothly and hop over the heat spots. i got a warranty and im getting akebono ultimate pads which they recommended for my set up. i thought the ebc's were to bitey, and chewed up my rotors.
I had ceramics and they will squeal, not too loud but its def there. jus do some research to see which squeal the most quiet. Stoppin power was a lil better than tradional but not worth the noise...JMO
I went back to traditional pads from autozone and all is quiet now
Akebono
Thanks for the info cashoit. I finally pulled the trigger on Akebono Street Performance for front and Wagner Therms for rear. We shall see. My car is loooooong overdue for maintenance overhaul/upgrades. Not to get off topic, but, just ordered the following from energysuspensionparts.com due to I am getting a lot of play with steering after my new struts were installed and a little dissapointed with performance:
Front Control Arm Bushings
Front Sway Bar Bushings - 20mm
MOOG-ES3438 - Front Outer Tie Rod End
MOOG-EV352 - Inner Tie Rod End
While installing struts, 1st mech stated my LCA needed to be replaced immediately. Several days later, had 2 front snow tires replaced w/Eage GT's and 2nd mech at diff shop said he didn't see anything wrong with LCA, but, tie rods are definately shot. I'm thinking to myself...wtf is this!!....
![Roll Eyes (Sarcastic)](https://maxima.org/forums/images/smilies/rolleyes.gif)
Kind of getting fed up. Makes you want to take courses in auto repair.
Anyway, having Brembo rotors, pads and all stuff aboved installed soon. I wonder if any licensed NJ mech org member wants to pick up a little extra cash and case of beer to do this work....
![Big Grin](https://maxima.org/forums/images/smilies/biggrin.gif)
I cant even tell u. I dont do my own brakes cuz i dont have jacks. I let my mechanic do it for me. Told him i wanted ceramics and new rotors, top line shyt
![Cool](https://maxima.org/forums/images/smilies/cool.gif)
I saw all the old parts so i kno he swapped them and it stopped a lil better with ceramics. Breakes felt tighter too. But when applyin brakes and slowing down from 15-0 mph, there was a quiet squeal. It used to **** me the hell off
![Mad](https://maxima.org/forums/images/smilies/mad.gif)
The max i have now, i swapped to tradional metallic and i dont hear nothing when slowing.
While installing struts, 1st mech stated my LCA needed to be replaced immediately. Several days later, had 2 front snow tires replaced w/Eage GT's and 2nd mech at diff shop said he didn't see anything wrong with LCA, but, tie rods are definately shot. I'm thinking to myself...wtf is this!!....![Roll Eyes (Sarcastic)](https://maxima.org/forums/images/smilies/rolleyes.gif)
Anyway, having Brembo rotors, pads and all stuff aboved installed soon. I wonder if any licensed NJ mech org member wants to pick up a little extra cash and case of beer to do this work....![Big Grin](https://maxima.org/forums/images/smilies/biggrin.gif)
Bumping an old thread because Centric Posi Quiet pads were mentioned. I just bought a set of these for my '99. One of each pair of pads (front and rear) comes with a metal bracket that sticks out about 1" from the back of the pad. This is attached to the pad; it is not the brackets that go into the caliper. Any idea where this goes? Is this the correct pad for the Maxima?
correct. I can see it loud and clear. Once your pad gets worn down almost to nothing but not completely these metal brackets start touching the rotor and you will hear high pitched squeal that tells you "time to change pads"...
on mine, they are on the outside for front and inside for the rear.
it doesn't matter unless your pads wear unevenly (they shouldn't but if your old ones did then I'd install it on the side that got the lowest prior to changing).
i can't believe you've never seen the wear indicator before. some pads don't come with them but the vast majority do.
04-16-2020 05:15 AM
HerpDerp1919
09-29-2015 02:02 PM
