Automatic taken apart? lost thread
Sup all. I have been looking for a thread from a long time ago of someone that took apart an automatic. There was a bunch of pictures included but I cant find the thread. Does anyone remember that or have it saved by any chance?
FOUND IT, http://forums.maxima.org/4th-generat...rnal-view.html
Sorry for the useless post, mods can delete if you'd like
It can be changed so that it will bypass the resistor at Wide Open Throttle (WOT) instead of at less than WOT so you get smooth shifts while driving regularly and hard shifts when you're flooring the gas pedal.
Btw: How are you new to this forum if you have 2601 posts?
DR Mod is the drop resistor mod, where you install a circuit that bypasses the transmission fluid pressure resistor, and forces the transmission to shift at full line pressure.
I have a quick question. I am wondering why does my reverse only work when I have the DR line disconnected. I get the creeping backwards when this DR is disconnected and when I have it back in no reverse and no reverse gear ingagements. I have a feeling that my gears for the reverse are ok,but the valvebody has some serious issues. I have some odor to the fluid so and I might have burnt up some clutches.
ef9
Oct 4, 2015 08:43 AM
Andy29
Sep 29, 2015 05:32 AM
