Headlight harness
Old Nov 7, 2000 | 04:21 PM
xHypex's Avatar
I bought new bulbs for my headlights. They worked fine for about 5 days, but then one died. I pulled the bulb out and the bulb was fried. One of the prongs was totally black and the light no longer worked. I put my stock lights back, but I may get another pair of lights. How do you upgrade the harness? I've been told that you can pick them up at any auto parts store, but what specs do I need and how exactly do I do it? The harness runs into a ribbed covering. Do I disconnect something in there or do I get to do some soldering?
Thanks for the help.
-hype
Old Nov 7, 2000 | 05:26 PM
Chunger's Avatar
My other car is a Hybrid
Unless you're good with wiring>>
buy the harness kit.
JEGS has it.
034-50.9104 9004 Harness Kit $50.99
Catalog Index | Hoods, Scoops, Appearance | Appearance | Accessories | APC Headlight Upgrade Harness
Old Nov 7, 2000 | 05:53 PM
SmoothMax's Avatar
OG
Carparts.com also carries the harness from APC. It's great and a must for high wattage bulbs. It makes em a whole lot brighter. Definetly worth it.
Old Nov 8, 2000 | 05:09 AM
Albertt's Avatar
Overwattage >>
-hype
Wasn't your problem here. The reason why the bulb blew out was because it was made poorly.
Getting the overwattage harness won't prevent bulbs from blowing, but will allow your system to handle higher wattage bulbs, safely and more efficiently. APC manufactures the harness, and it can obtained from Carparts.com, Jeg's or Autosydicate.
Buy higher quality bulbs...inspect them before you use them. Usually, what causes them to fail is that the bulb glass leaks the halogen gas out, causing the filaments overheat and burn out.
doctorpullit
Oct 28, 2019 10:58 PM
doctorpullit
Mar 29, 2016 11:08 AM
magiconthetire
Oct 26, 2015 09:03 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
Noela
Sep 26, 2015 08:22 AM
