egr CODE 0302
Old Mar 27, 2010 | 03:40 PM
HoLLaAtMyMaXx's Avatar
egr CODE 0302
THOUROUGHLY cleaned egr vlave, throttle body, replaced knock sensor and cleaned ivac still getting the code... i really dont want to do that whole job over.. anyidea...been two weeks with no inspection because of thiis code
Old Mar 27, 2010 | 04:02 PM
done12many2's Avatar
Did you clear the code?
Old Mar 27, 2010 | 04:11 PM
yes it came back in 30miles
Old Mar 27, 2010 | 04:20 PM
used parts's Avatar
did you clean the small tube?
Old Mar 27, 2010 | 04:35 PM
cleaned the topone in the back connected to the ivac
Old Mar 30, 2010 | 02:45 PM
djchan's Avatar
repost...My P0400, 0302 cel was solved by replacing the EGR solemoid valve ( green Connector ). I replaced it, but took apart and cleaned the old one and now that one is working fine too. Easy to clean, only one moving part inside, a spring and 2 O rings. Hard part is taking it out and putting it back in. So save some money and try cleaning it first...david
Old Mar 31, 2010 | 06:10 PM
can you tell me exactly where it is please?
Old Apr 1, 2010 | 11:18 AM
djchan's Avatar
I type really slow...so here are some links...you can test it first to see if it clicks before removing it. Also if you have a "99 the this is not your problem. GL
http://forums.maxima.org/4th-generat...oid-valve.html
http://forums.maxima.org/4th-generat...d-contorl.html
http://forums.maxima.org/4th-generat...lve-issue.html
Old Apr 11, 2012 | 05:26 PM
hungtdao's Avatar
See my solution in this thread http://forums.maxima.org/8425603-post13.html
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
