Where is the ECM Wiring harness?
In front of the center console, under the dash. The harness connector is accessible from the passenger side of the center console, behind a small black panel. Remove the panel, you'll see a bolt that secures the connector. The connector is like a parallel port plug (if you can remember what they were) only a lot bigger.
If you remove the black panel, you will see a white plastic connector with a bolt in the center (10mm I believe). Remove this bolt, and you should be able to remove the white cover. Then screw the bolt back in without the white cover on there, allowing access to the wires while plugged in. It's been a while since I've had to do this, but if I remember correctly, this is the best way to access it.
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
