g35 tires rubbing, suspension change solve the problem?
Old Mar 30, 2010 | 06:20 PM
elgordito941's Avatar
Hey i know this thread has been done a million times but when i search all i get is broken links and pages. And also sorry for putting this in the 4th gen general section but i got no love on the tires section so im trying here.
SO i have these g35 18 inch 7 spokes and they rub in the back against the fender.
Currently i am on stock suspension that will shortly hopefully b replaced with h tech springs on illumina struts. (ordered and comeing in this week)
Is it possibly that now i wont rub? will i not dip as much? and what is the recommended tires for the g35's for the 4th gens?
two tires need replacing so what size should i go with?
Sorry i know nothing about tires
Old Mar 30, 2010 | 06:52 PM
RA030726's Avatar
I'm nutty for Nissans
You may have to roll your fenders. Lowering would probably make it worse.
235/40/18
Old Mar 30, 2010 | 06:57 PM
cartman854's Avatar
Your tires must be to thick, im running 20"s with 245/35/20 tires, and no rubbing. Im also running stock suspension, and lowering will make it worse, at most upgrade the struts, but no lowering springs.
Old Mar 30, 2010 | 07:14 PM
yea its only by a little bit. maybe the 235 40 18 size will solve it right now im 245 45 18
Old Mar 30, 2010 | 08:33 PM
cartman854's Avatar
maybe, go to a tire place and ask em to test fit it.
Old Mar 30, 2010 | 09:23 PM
MAXC's Avatar
Keep in mind that he is using G35 rims so the offset is different. Thats the reason for the rubbing on the rear. The G & 350z rear rims, even though they will fit, you'll have to either roll or trim the rear fender lips. Some people dont have to do this. But it looks like you are.
Old Mar 31, 2010 | 10:09 AM
MAXC's Avatar
Originally Posted by Bamfy98
You can buy spacers. They are little plates that go around the lugs, you put them on before the rim. They will move your wheels further out to prevent rubbing, but your wheels will bulge out the sides a little more like a truck, but hey I like that look sort of.
Can you please tell how you came up with that? Moving the wheels out will only allow the fender to Not rub the side of the tire, but instead rub the top of the tire. So spacers would not bet the thing to do.
Old Mar 31, 2010 | 10:13 AM
buttonhook's Avatar
235/40/18 are the same profile height as stock 16" 4 th gen tires and wheels the 245/45/18 are too tall and wide
Old Mar 31, 2010 | 12:14 PM
wirelessdude04's Avatar
nice
Old Mar 31, 2010 | 07:20 PM
ok solution found i went in today i got 235/40/18 and they fit great. with my drop and new suspension my car wont dip as much hopefully and i wont rub at all. worse comes to worse i guess ill roll my fenders.
Matt93SE
May 24, 2019 02:58 PM
kjlouis
Nov 24, 2018 06:09 AM
homeyclaus
Sep 3, 2015 06:15 PM
RealityCheck
Aug 5, 2015 06:18 AM
