How to remove engine temp sensor?
Old Apr 2, 2010 | 12:54 PM
dan1el's Avatar
I broke the engine temp sensor removing the front cylinder head. I can't figure out hot to get the old one disconnected from the wire harness. IT looks like you just pull, but I'm scared of breaking the harness connector. Any advice?
Thanks, Dan
Old Apr 2, 2010 | 05:13 PM
Nealoc187's Avatar
SLOW
if you're talking about the one that goes to the gauge cluster (the small sensor) you just pull it off. if you're talking about the larger one you just press the clip and remove it like any other connector. nothing special about either one...
Old Apr 2, 2010 | 09:30 PM
dan1el's Avatar
Yeah it's the one that goes to the gauge, the "engine temp sensor". The other one is the coolant temp sensor. A week or so ago I broke it off at the nut. It snapped off like a freakin lego so I'm scared of pulling on it, but if it just pulls then I'll try it.
Thanks, Dan
Old Apr 2, 2010 | 09:34 PM
Mistertones's Avatar
Thanks, Dan
Use a flat head screw driver, place it on the base of the plug and push up while squeezing the clip.
Old Apr 3, 2010 | 02:46 PM
dan1el's Avatar
Thanks a lot, thet's exactly what I was looking for and about to try lol.
kjlouis
Nov 24, 2018 06:09 AM
Slamrod
Sep 3, 2015 07:38 PM
raffivegas
Aug 23, 2015 09:54 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
