Underdrive Pulley on Ebay
I did a search and from what i learned get the OBX. Ebay has these too. The how-to descibes what other parts are needed. U need another belt and crank pulley o-ring.
Does anybody know where to get the belt?
I wouldnt get one unless it was of high quality like the UR pulley. Going with the UR pulley just requires a new belts which they lists the sizes need on their site. There have been members here who have had issues with the cheaper pulleys breaking and etc.
UR makes one.
Yo man UR pulley cost 600 for stock size!!!!!! thats crazy expensive!!!
U wd have thought i was buying a new engine or something. Dang!
The UR underdrive comes with timing ring bolts and sleeves for the o-ring to ride on. Is all that really necessary??
Bottom line is this thing more trouble than its worth??
Im not gonna spend 600 bucks for a pulley. OBX has them for 75 bucks. Any aftermarket pulley is made of high strength aluminum and it has a timing mark to fit onto crankshaft, its like looking at a Greddy or Ebay exhaust. They both work buy Greddy is the name brand. OBX is a name brand too right
I can think of way better uses $75 can be used for (Quick example: ES Poly euro stuff).... Since you're buying a UDP, we can all assume that you already have Headers, Y-Pipe, High flow cat and B-Pipe right? Get what I'm saying?
An UDP is one of those last mods to do, same as a lightened flywheel, your car really isn't going to be much faster, but if you already have done all of the other major modding then and looking for that extra edge then get a UDP....
just had one put on my Max, got off E-bay. I don't care what anyone says you can tell the difference... All the other mods except for Y-pipe were for noise only, so I am not the guy who says everything works.
I got the belts from Napa, I only needed the larger one because the tech said the the stock smaller one fit fine. Only a few hundred miles, but awesome so far, and the part was not cheesy and well done.
I got the belts from Napa, I only needed the larger one because the tech said the the stock smaller one fit fine. Only a few hundred miles, but awesome so far, and the part was not cheesy and well done.their both pretty straight forward when removing/installing. i picked up everything i needed to know about the crank pulley just by browsing here. you can also borrow a tool from autozone to remove it if you have to but you have to pay upfront for it and get your cash back when you take it back.
also so getting a UDP would be pointless even though you have to replace the pulley anyway? if it costs the same and will end up doing something for you in the long run after all the other mods, why not get it now instead of a stock replacement. either way your getting it fixed right or wrong
here's the thread if you havent seen it already
http://forums.maxima.org/4th-generat...ley-broke.html
Flava and Aack both have the UDP. Neither recommended it and them dudes are Jedi Master Maxi Modders!!!.
There are def more ppl against it than for it. I saw the price and i thinks the OBX FTW. UR looks about the same machining wise and made of the same material as OBX so i really cant justify paying 3x as much for it.
If i do decide to buy i have to get the o-ring and the belts.
There jus doesnt seem to be alot of veteran orgers who support it.
Anywho.... I don't support it as an early modification, for $89 you can get those suspension support brackets, or hell $61 can get you some poly euro suspension brackets, all mods that will make MUCH more of a difference then just a UDP or Lightweight Pulley.
I wish I could drive around a maxima w/o a UDP, it's too hard to compare to any other engine but a VQ, because the VQ is a short stroking light motor that already revs pretty damn easy, so even w/o a UDP I bet this car is much easier to downshift in than... Miatas, Mustangs, S2Ks and other cars I've driven.
I've heard to steer clear of UDP's because most factory pulleys have a harmonic balancer built in and most lightened after market pulleys don't. What are your guys' thoughts on this? I've heard that without a harmonic balancer the crankshaft on the pulley side actually begins to resonate in a very bad way.
"Performance enthusiasts have been known to remove harmonic balancers, usually when the balancer is attached to the crank pulley, deciding that they aren't necessary and their mass reduces the performance of the engine. However, this is unproven and potentially very risky because the danger of damage to the engine from the vibrations the damper is intended to prevent is too high."
I can tell you that having the Lightened flywheel is something you definately notice. Revs climb much quicker, but fall just as quick as well. I didnt notice much usaing the UR UDP, but paired with a flywheel Im sure it helped.
What I dont get is how some will bash these lower end companies on certain products like lets say the STS, and recommend a bigger name brand yet on something like this which is a bit more of a crucial item they feel it ok to cheap out on.
FWIW,
an old friend of mine Dubbya had his Motostorm pulley crap out on him and cause some good damage.
http://forums.maxima.org/all-motor/3...ank-shaft.html
You get what you pay for.
Just about every car manufacturer uses a thin rubber ring between two concentric pieces of a crankshaft pulley. The amount of damping can be varied by how thick the ring is.
The harmonic damper is for damping out torsional vibration. It has nothing to do with engine balance. Even a perfectly balanced engine will have torsional natural frequencies that are self-excited by engine rotation, and the longer crankshaft length of an I-6 will result in lower natural frequencies with higher amplitudes than a V6. There is a certain amount of torsional damping in the oil film in the main and rod bearings, but apparently not enough for the Beemers, hence the need for the damping provided by the rubber ring. Also, apparently it is not as critical for the VQ engine, since people seem to get by just fine without it.
Just curious, you speak from experience or from what you have read and heard?
Flava said it right above already....
But from what I've learned on previ cars, UDP is just one of those last things to do, especially when there are mods to be done that can make a considerable change in your car's performance.
Why don't they make a smaller diameter, lighter alternator pulley to go with the smaller, lighter, crank pulley? You would save even more weight and better yet, the alt. wouldn't be underdriven.
I went with the UR after my research on this forum said some of the other cheaper UDP's break.
So far so good. I've put about 500 miles on it. The car does feel lighter on the accelerator, and seems to speed up faster. When the car is in motion it feels smooth.
A mentionable negative, the car seems to vibrate more, and there are some rattles because of the new UDP. She feels angry and itching to go. This phenomenon only happens during idle.
If you go on the UR site, it will tell you the belts you will need. My mech installed the belts and found the PS belt to be too short, so maybe another 1/2" PS belt would be better.
3 other things worth mentioning. (1) I've read that this mod helps ppl with an Auto more than a Manual. (2) The harmonic balancing I've heard is a thin layer of rubber in the stock pulley which keeps it smoother. The aftermarket ones dont have it. (3) Remember to get the oil seal.
litch
123
Jan 4, 2024 07:01 PM
magiconthetire
Oct 26, 2015 09:03 PM
220k+ A32
25
Oct 3, 2015 09:09 PM
soybeanz
Sep 25, 2015 10:46 AM
