Is it normal to have only the drive side wheel to get most of the brake dust? I'm getting lots of dust on the driver side and almost none on the passenger side.
Quote:
yup, thast what i would do. If the pads on the driver side are less than the passenger side, your caliper is prob starting to seize or you need to re-grease then return bolt that moves.Originally Posted by ajm8127
Check your pads to see if they are wearing evenly from side to side.
Quote:
+1 Originally Posted by ImmaSquashYou
you are unfortunately probably going to have to replace your caliper (i would do both). you an keep your old rotors and pads though so it's not a total loss
Originally Posted by Feldman
+1 you are unfortunately probably going to have to replace your caliper (i would do both). you an keep your old rotors and pads though so it's not a total loss
I'm pricing calipers now!!! They go for big bucks
they're $50-60 at the local parts store.
before you start freaking out about it, pull the wheels off and actually look at the car.
Is it pulling to one side when you brake?
When you say 'just got my brakes done' do you mean you did them, or you had them done. If some shop, they should have caught the prob. I'd go after them to maybe get cut rate on labour at least.
same thing happened to me after I tried to justify being cheap on front pads and rotors.
pass. side smooth, and driver side etched, and tons of brake dust... BTW my calipers were perfectly fine, just got what I paid for.
pass. side smooth, and driver side etched, and tons of brake dust... BTW my calipers were perfectly fine, just got what I paid for.Newbie - Just Registered
hey,im new on here but my pads are good and they sound like there grindind and lots of brake dust,but i,ve got bigger problems wit my car that i have to get fixed first
"I'll take a look.
Sucks casue I just got my brakes done."
Gotta completely bleed and change brake fluid, re-surface rotors, and grease the pins. U probably got some goop stuck in ur break lines OR like u said u went and had urs done :/. never trust a under trained "tech" work on breaks. i do all my ownt work, but try to do wht i said and u will have a whole new ride with ur breaks and check ur master!
Quote:
I'm hoping thats the problem. Anyways I'm having the car checked out today.Originally Posted by maxx0831
I had the same thing happened to me abt 2 weeks ago, found out it was one of the sliding pins that seized
