98 SE: Engine stumble, then CEL0608 ?
Old Apr 11, 2010 | 04:24 PM
MaximA VlaD's Avatar
Hey guys/gals,
this is a 98 SE, 5 spd, with 236,000 miles.
the girlfriend drives it everyday. today I drove it and noticed engine stumbling on moderate acceleration, especially in higher gear with low RPMs. while i was trying to diagnose it as I'm driving it the CEL started to flash. After several flashes it stayed on.
when i got home a few minutes later, i checked the CEL code - 0608, Cyliner 1 misfire (here is the diagnosis from pmohr's decoder: http://boredmder.com/ecucodes/index.php?year=MY1998&DTC=0608)
then i looked under the hood and noticed some dark oily leak spot from the base of the intake manifold, pretty much along the entire base where it is mounted on the block on the gasket. While I was looking, the CEL went away.
I have a feeling that the intake manifold leak and perhaps spark plugs might be a cause, as well as other things like fuel filter and coil packs. Most likely the throttle body needs a good cleaning, since this car also takes more than a normal number of cranks to start the engine - about 3-4 seconds or longer almost all of the time.
I just want some of your opinions as to where I should start and pay closer attention to. This way I don't spend too much time on something insignificant to this problem. Maybe someone had same symptoms and similar results.
Thanks for your help!
Old Apr 11, 2010 | 04:52 PM
Trini Boom's Avatar
Originally Posted by MaximA VlaD
Hey guys/gals,
First, I would start by removing the coil and examine it and the spark plug and post some pics.
Old Apr 12, 2010 | 07:40 AM
buttonhook's Avatar
sounds like a bad coil pack and/or plug. Give it a tune up and it should fix it
Old Apr 12, 2010 | 08:25 AM
cashoit's Avatar
yeah it doesnt sound like a major deal. If its leakin oil, u may have to replace rear valve cover gasket. THen from there, maybe coils and plugs.
James92SE
142
Jan 2, 2024 09:23 AM
Mar 12, 2020 12:06 AM
RinconI30
Nov 10, 2015 10:55 PM
msellas
Sep 23, 2015 09:16 PM
Socalstillen
Sep 20, 2015 11:46 PM
