Shifter return spring
Old Apr 16, 2010 | 07:11 AM
wirelessdude04's Avatar
JUst put a new clutch in and i cant figure out where the other part of the shifter return spring connect's too. Right now it connects too the twe brackets coming down which hold the shifter rod into place. I checked the FSM but no good pic of where it goes. Any help please
Old Apr 19, 2010 | 03:44 AM
Nismo's Avatar
Right under under the shift lever. There should be 2 holes, one on the shift rod and one hole on the opposite side on the support rod
Cant find a pic of a maxima but its pretty similar to this
Old Aug 1, 2010 | 04:38 PM
VQuick's Avatar
Chassis Freak
My return spring must be rusting because lately I'm getting sticky movement and weaker return to the central neutral position. It's been years since I installed my STS. Can the return spring be replaced without too much work, or does the exhaust have to come down?
Old Aug 4, 2010 | 08:39 AM
Flava_24/7's Avatar
Boosted Panda
You can get to it by removing the cat or your center section of piping. No need to pull the whole exhaust out. The heat sheild has to come off if you still have it.
For me, it was easy to do since I have no cat and no heat sheild.
Fbana41
Aug 29, 2016 12:18 PM
MaxLvr21
Oct 17, 2015 12:11 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
atriuum
Sep 28, 2015 01:19 PM
