Help with OOIV swap?
Old Apr 16, 2010 | 10:33 PM
Kico's Avatar
Today I decided to do my OOVI swap I called it quits for the night but, so far I have got the 2000 LIM injectors and fuel rail on and started removing EGR so I'm looking for link or how to tips on installing injector pig tails on OOIV swap any help greatly appreciated thanks. I'll check back in the morning if any one could chime in thanks.
Old Apr 16, 2010 | 11:25 PM
MaximaSpd85's Avatar
theres two wires on each clip....just match up the reds together and whatever other colors are there and you should be straight. if the colors dont match like that, just make sure the new clips wire in the same way the old ones come off. very simple
Old Apr 17, 2010 | 01:19 AM
schmellyfart's Avatar
Old Apr 17, 2010 | 07:05 AM
Kico's Avatar
Thanks for the help I'm going to start where I left off yesterday maybe later I'll have more questions.
Old Apr 17, 2010 | 07:11 AM
NmexMAX's Avatar
dot dot dot ...
00VI > OOVI
Old Apr 17, 2010 | 08:18 AM
hornepirate's Avatar
Originally Posted by NmexMAX
00VI > OOVI
Old Apr 18, 2010 | 07:20 AM
Kico's Avatar
I finished my OOIV last night my car started and idle fine I'm going to go over everything this morning and adjust the vias to open and close at the right rpm with my AFC I'll keep you posted.
Old Apr 18, 2010 | 02:02 PM
Kico's Avatar
Ok I have a few questions, first question I need some help on is when I ran my AFC to the vias I connected red wire on vias to pink wire on my AFC, brown wire to a ground and do I supply vacuum to the vias yes or no? Second question can any one give me some info. on settings that I could set my AFC at until I get it tuned later this week. Third question, I have a check engine light on and the code is p1105 malfunction control fuel air metering, thats what my scanner said when I scanned it 20mts ago. Any help will be greatly appreciated
Old Apr 18, 2010 | 02:44 PM
shadyonedeath's Avatar
stop calling it an OOvi, its a 2000 variable intake. 2000 = 00 VI = Variable Intake. Double zero's son.
And go to the ALL motor section. Every answer is there if u just search
Old Apr 18, 2010 | 03:18 PM
B_Eaze's Avatar
Isn't there a complete manual in pdf form in there and several write ups?
Old Apr 18, 2010 | 06:19 PM
Kico's Avatar
As far as the vias goes I got it working great and car moves like lighting! No current codes, but there is always tomorrow.
Old Apr 27, 2010 | 05:36 PM
first to none's Avatar
i got a question what exshaut did u use on ur new swap cuz im doing the same swap but my old y pipe doesnt fit thats my only concern righ now
Old Apr 27, 2010 | 06:15 PM
Nupemax96's Avatar
yes there is...I believe this is the link (http://kyleb.semanticalsyntax.com/00VI_Manual_v1.pdf)
Old Apr 27, 2010 | 06:33 PM
B_Eaze's Avatar
An 00VI has nothing to do with a y pipe..... maybe u should bring it to a someone who knows about maximas.
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
JonBlz
Oct 5, 2015 06:02 PM
ef9
Oct 4, 2015 08:43 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
