Looking for a how to on a clutch job
Old Apr 22, 2010 | 09:03 AM
xkazik's Avatar
Hello , i looked at the 4gen how to's and i found one but the link its dead. does anyone have any how to's on a clutch job ? im looking to do my clutch soon and just want to check it out. thx
Old Apr 22, 2010 | 09:36 AM
MaximaSpd85's Avatar
a haynes manual should be sufficient. but in a nutshell:
drain fluid
remove intake and battery (basically anything in the way, including unplugging sensors)
remove starter
unbolt slave cylinder and other lines etc
remove axles
unbolt tranny bolts
remove tranny mount
you should be able to grab the tranny by the starter hole and guide it to the ground
from there its just unbolting the pressure plate and installation is reverse
if you need more then that, haynes is your friend if u cant find a writeup
Old Apr 22, 2010 | 10:03 AM
xkazik's Avatar
do i need to remove any sub frames or anything like that ?
Old Apr 22, 2010 | 10:48 AM
S1cTech's Avatar
No u dnt have to remove the motor subframe/crossmember support infact u can get away with removing one axle (drivers side) if you feel daring enuff.
Old Apr 22, 2010 | 10:50 AM
S1cTech's Avatar
Also being a senior member i would hope you know there is various writeups all over the web. Maxima.org isnt the only place. Motorvate, vqpower, nico, google ir ur pal... jus saying
Old Apr 22, 2010 | 10:56 AM
cashoit's Avatar
Jus make sure to sand / polish down the mating surface of engine to tranny. PPl try to do their own clutch job and neglect to do this and have starting / grounding issues later.
Old Apr 23, 2010 | 04:53 PM
komik's Avatar
black maxed95 has a good write up with pics here: http://forums.maxima.org/4th-generat...intensive.html
That plus a Haynes manual is what I used. I removed both axles, but left the cross member in place. I bought a transmission jack from Harbor Freight to make it easier. I have removed other transmissions with a floor jack, a block of wood, and an assistant, but the tranny jack is much easier.
Old Apr 23, 2010 | 05:59 PM
NISSANMAXIMA91's Avatar
look up JTZMax's tranny rebuild writeup. No, youre not rebuilding the trans, but it has the steps and pics. pretty straight forward really
Old Apr 23, 2010 | 06:21 PM
komik's Avatar
Yes! That was the other topic I read while doing mine. There is actually a link to it (http://forums.maxima.org/4th-generat...te-up-pix.html) in the first post of the topic I posted above. That thread then contains a link to http://forums.maxima.org/4th-generat...nsmission.html, which also has some good pictures.
Old Apr 23, 2010 | 06:54 PM
JtzMax's Avatar
Whatchyou say?
thanks guys! I'm glad that after all this time, my write up is still getting use.
Old Apr 23, 2010 | 07:19 PM
Old Apr 24, 2010 | 07:20 PM
Snypa's Avatar
Remove driver side axel....intake...battery....transmision.
Unbolt clutch, flywheel.
Rewind. !
Old Apr 24, 2010 | 07:35 PM
Blakfreestyle's Avatar
Excellent write up!!. Can't thank you enough. I did the flywheel replacement about 2-3 weeks ago. I did not remove the crossmember but I did remove both axles.
Best part about the max is that the brakes and balljoints don't need to be disconnected for the axle removal. With airtools the hardest part about the clutch job is the transmission removal and installation. This job goes a LOT easier with the help of a friend to maneuver the transmission.
Old Apr 25, 2010 | 10:08 AM
sc10692's Avatar
Im pretty sure motorvates down
Old Apr 25, 2010 | 12:26 PM
xkazik's Avatar
Thank you guys for all you help . now im just going to order a clutch kit. still debating between 4 gen or 5 gen clutch . and yest motorvates is down .
Old Apr 26, 2010 | 04:53 AM
S1cTech's Avatar
why would there be a debate? Get the 5th gen it is a better stonger clutch and will last longer. It is not as hard to press as ppl say. Just harder.
user 11122324
42
Jul 18, 2022 03:35 PM
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
doctorpullit
Mar 29, 2016 11:08 AM
carlosvq30
Sep 26, 2015 09:44 AM
