Turn Signal Mod Question
Old Dec 10, 2001 | 06:59 AM
krzymax's Avatar
Maxima owner since 2000
hello everybody. wondering if there is a website which explains how to make the turn signal and corner light to flash like this:
*picture from custommaxima.com*
also, i'm rewiring my fog lights to be on with my parking lights. if the corner light flashes like in the picture, would that make the fog lights flash as well? i wouldn't want that to happen.
Old Dec 10, 2001 | 07:16 AM
Capitone's Avatar
Re: Turn Signal Mod Question
Yes there is....go to Maximadriver.com and take a look at the "How2" section. It'll walk you through it.....relatively simple mod to do
Old Dec 10, 2001 | 04:42 PM
krzymax's Avatar
Re: Re: Turn Signal Mod Question
it didn't really help.
Old Dec 10, 2001 | 05:06 PM
clee130's Avatar
Try this link: http://www.geocities.com/amixam69/nissan/markerblink
Old Dec 10, 2001 | 05:18 PM
krzymax's Avatar
thanks! will doing this mod affect my rewired foglights?
Old Dec 10, 2001 | 05:25 PM
clee130's Avatar
Nope.
Old Dec 10, 2001 | 05:32 PM
NightRider's Avatar
Easy, cut and splice you sidemarker's negative (black) to you turn signal's positive (green)
Old Dec 10, 2001 | 07:11 PM
krzymax's Avatar
Success!
I only had enough wire taps to do one side, so i did the driver side corners. followed the diagram and was finally able to rewire my blinkers. i must say, it looks better than the original. gotta love these small inexpensive mods...
Old Dec 11, 2001 | 07:00 AM
Capitone's Avatar
FYI
If you've rewired your Corners (make em brighter) as well you may or may not experience a blown fuse. Don't panic, just up the fuse to I believe it was ten and problem fixed. Run a search on "corner lights" and Im sure you'll find the exact remedy for this.
Old Dec 11, 2001 | 07:47 AM
krzymax's Avatar
Re: FYI
i did a search and didn't really find anything. is it the mod that is explained in Cheston's site? the "rewire your corner lights"?
Old Dec 11, 2001 | 07:51 AM
99maxi's Avatar
what happens to the marker when you are not signaling? is it on or off?
Old Dec 11, 2001 | 08:01 AM
krzymax's Avatar
it's on when you have the lights on.
Old Dec 11, 2001 | 08:05 AM
Sprint's Avatar
grasshoppah
Old Dec 11, 2001 | 08:09 AM
krzymax's Avatar
Originally posted by SprintMax
grasshoppah
forgot about that!
grasshoppah
Old Dec 11, 2001 | 08:48 AM
BluFlame's Avatar
how about hazards? do they still work normally with this mod?
Old Dec 11, 2001 | 08:59 AM
SuDZ's Avatar
Whats a wire tap? Does it just mean to splice the wires together?
SuDZ
Old Dec 11, 2001 | 09:37 AM
krzymax's Avatar
without lights on, both the turn signals and corner lights will blink together when the hazard button is pressed. if you have your lights on and press the hazard button, it will look like the image i posted in this thread.
grasshoppah
Old Dec 11, 2001 | 09:51 AM
clee130's Avatar
Basically, yes.
A wiretap is a little thingie that does the splicing for you. But you could also do it the old-fashioned way by cutting the wires and splicing them together.
You can find wiretaps at a hardware store or at Home Depot. Should be relatively cheap for a handful of them.
SuDZ
Old Dec 11, 2001 | 12:28 PM
Capitone's Avatar
Re: Re: FYI
yea thats it. Try "Corners out" or "blown fuse" or "parking lights out" with the search option here, you'll have to do a little diggin to get what your want, hopefully you won't need it, but if your fuse should blow, try search'n for this remedy.
Old Dec 11, 2001 | 03:26 PM
SuDZ's Avatar
Re: Re: Re: FYI
Or for a little preventive maintenence just replace the fuse now with a bigger one. Fuses are cheap and come in handy, just keep the extra ones in your glove box. Plus it only takes a minute to relpace it.
SuDZ
Old Dec 11, 2001 | 06:23 PM
krzymax's Avatar
SuDZ
fuse... you mean the grey thing where i put the bulbs in? or is it those colored rectangular things right next to the hood release button? as you can see, i'm very car illiterate...
Old Dec 12, 2001 | 05:11 PM
krzymax's Avatar
*bonk*
Old Dec 13, 2001 | 03:07 AM
KWheelzSB's Avatar
Right. The fuse panel below left of the steering column - can be removed to expose the fuse bank. Refer to your owners manual for the specific fuses you'll need to swap.
Old Dec 13, 2001 | 01:51 PM
SuDZ's Avatar
I did this mod today on my lunch break here at work. Takes like 5 minutes a light and the best part is it doesnt cost anything. I recommend this mod just cause it looks cool. Once my clears come in it will look even better though.
Thanks for the tip guys.
SuDZ
Old Mar 28, 2002 | 02:14 PM
Riot^'s Avatar
bulbs?
2 things...
1 - just curious, you guys use yellow bulbs in the markerr and blinker or both one of those hyper Xenons or whatever they are now?
I have a Xenon in the sidemarker, but I still blink yellow. It will look weird once I do the mod
2 - When you cut the ground from the marker and splice it to the + of the blinker, just to understand correctly, you cut the ground in two, completely or just "splice" it and run a new wire from the ground to the +? I am not too hot on electronics.
If it us cut completely, I guess one of the wires will be taped up and juct dangling there inside.
Correct me if I am wrong.
thanks
03VQMAX
Oct 2, 2016 09:36 AM
Maxima_Joe
Nov 25, 2015 08:19 AM
sake1bs
Sep 19, 2015 09:32 PM
Maxima_Joe
Aug 27, 2015 12:01 AM
