Finall decision 5 gen clutch over 4 gen, now what else do i need ?
Old Apr 27, 2010 | 02:35 PM
xkazik's Avatar
I ordered a 5 gen clutch kit for my 4 gen from daveb, i also ordered amsoil, what else will i need before starting to change my clutch ? My friend is doing all the work i just want to get all the parts for him . any help would be appreciate it, Im looking to get everything so i wont be stuck on the weekend with the car not drivable, do i need any seals or anything like that ?
Old Apr 27, 2010 | 03:33 PM
99BlackMaxMS's Avatar
Clutch kit (disk and pressure plate), alignment tool, gear oil, throwout bearing, axle seals (optional, but recommended). All that and you should be good.
Old Apr 27, 2010 | 03:40 PM
xkazik's Avatar
Where do I get the aligment tool? Does it come with the clutch kid ?
Old Apr 27, 2010 | 05:26 PM
9maxima5se's Avatar
The alignment tool comes with the clutch kit
Old Apr 27, 2010 | 06:20 PM
ajm8127's Avatar
I just received a fifth gen clutch (pp, disc and bearing) from Dave Burnette and did not receive an alignment tool to my dismay. It obviously has to match up with the splines in the disc so is this a Nissan specific part, or can it be had from any average autoparts store?
Old Apr 27, 2010 | 07:17 PM
JNCoRacer's Avatar
Just the tip.
You can get it anywhere. It didnt come with the 5th gen kit I ordered too. You can borrow one from a friend (like I did) or do it the cheap way and use a broom handle.
Old Apr 27, 2010 | 07:37 PM
MaximaSpd85's Avatar
get yourself some sandpaper so that u can scuff up the flywheel a little
Old Apr 27, 2010 | 08:16 PM
+1 I forgot about that step...also sand down the contact points around the entire edge of the bellhousing.
As others said, you can get an alignment tool from any auto parts store for relatively cheap. IIRC, my 5th gen clutch kit didn't come with one either.
Old Apr 27, 2010 | 08:56 PM
xkazik's Avatar
Wait what do I need to sand down ? I'm get the flywheel resurfeced
Old Apr 27, 2010 | 09:32 PM
f550maranello2's Avatar
just use a 14mm deep socket with some tape around it...lol
Old Apr 27, 2010 | 09:46 PM
Nismo's Avatar
In that case, just make sure its degreased and you are good to go.
Old Apr 28, 2010 | 09:10 AM
xkazik's Avatar
sounds good . i just need to find out if my friend has the aligment tool at the garage
Old Apr 30, 2010 | 09:52 AM
xkazik's Avatar
does anyone know where can i get a aligment tool ?
Old Apr 30, 2010 | 11:17 AM
Nealoc187's Avatar
SLOW
any parts store, as someone already stated...
or you can just use a socket with tape on it and your eye if you're good at aligning things by sight. i've never used an alignment tool personally. always eyeballed it.
Old Apr 30, 2010 | 11:26 AM
xkazik's Avatar
thx a lot , for the help. Im starting this afternoon and since its weekend time im trying to get everything i might need so i can finish tomorrow . Still need to find a place that can resurface my flywheel
Old Apr 30, 2010 | 03:15 PM
Nismo's Avatar
You should first find a place to resurface it before you start unbolting things.
Old May 3, 2010 | 06:37 AM
Snypa's Avatar
check it yourself before spending to resurface. If its doesnt have gouges and dents n stuff, just rub it down with some sand paper and you should be good.
MAXSE5SPD
Sep 17, 2022 04:00 AM
BkGreen97
Apr 2, 2016 05:47 AM
iflexsteel
Sep 2, 2015 08:04 AM
Lowered_a33
Sep 1, 2015 07:49 PM
