Missing part of my intake (OEM) (pics)
Old Apr 28, 2010 | 10:25 AM
khemraj1999's Avatar
Hey guys, i bought a 97 maxima GXE a few days ago, i noticed that part of the intake is missing at the bottom. This is from the front(under the hood); one leads down and the other leads towards the back (air filter). The one that leads down wards seems to be missing something..maybe a cap or sumtin?
TOTAL 4th GEN NOOB, this is my first 4th gen...couldnt find any engine pics to compare
Thanks a million.
Old Apr 28, 2010 | 10:35 AM
cashoit's Avatar
Its supposed to be attached to an air reservoir.
somone had an short ram installed. They put the stock back on when they sold u car. Jus tape the bottom of it off with grey masking tape. I did it, Works no prob
Feldman's Avatar
The 5th gen is a little different but a pretty similar design. There is a box that that tube leads to down there is designed to make the intake quieter I am assuming the 4th gen has this too. When i got my car that piece was just kind of loosely sitting there so i took it out and put it in my trunk. You are fine without it
Old Apr 28, 2010 | 11:23 AM
maxima 21's Avatar
I agree. You are fine without it. If it means somethin to you, I wld be surprised if a junk yard charged more $15 bucks for it.
Old Apr 28, 2010 | 01:41 PM
RA030726's Avatar
I'm nutty for Nissans
Better yet attach a hose from a wet dry vac on it and route it down to the fog light area.
If you want to cap it off just use the cap to a spray can.
Old Apr 28, 2010 | 02:08 PM
Goodspeed91's Avatar
Intercoolerrr!!!!
Has anyone noticed a noise difference with the bottom part missing?
Old Apr 28, 2010 | 02:37 PM
Thanks everyone. I may get cold air intake instead of getting the air reservoir.
Old Apr 29, 2010 | 06:01 AM
ampire's Avatar
Any power differences using that reservoir versus not using it/routing a hose lower?
Old Apr 29, 2010 | 06:55 AM
cashoit's Avatar
yo thats an interesting idea Sutter. jus gotta be careful and aviod large puddles
Old Apr 29, 2010 | 08:05 AM
MaxiNone's Avatar
do you have a filter? my car came with the cone filter on the mass air and didnt have that what you have pictured. i believe its just the plumbing that goes through the fender or bumper to try on bring in the air from outside.
Old Apr 29, 2010 | 06:40 PM
RA030726's Avatar
Its a car. You shouldnt be fording rivers. Water is always an issue, but the beauty of the vacuum hose is you can pull it off in seconds if you do want to try your luck with puddles.
Old Apr 29, 2010 | 08:26 PM
aznprid972's Avatar
If you still have the snorkel part attached, it'll suck air through that before it starts sucking in water from below.
Guess I just gave myself another reason to give this mod a try as well
Old Apr 30, 2010 | 06:01 AM
cashoit's Avatar
@ fording rivers. Well you know, couples wks ago we had flooding up here in New England...water level got pretty high ha!
Yup. Water denser than air. Good point. I taped off the hose the OP is referring too cuz i have a short ram and i wanted the onrush of incoming air directed towards the cone filter. Now i got heat shileds over the filter and MAF ato totally enclose the entire area. I get good pull with that setup.
vingodine
45
May 21, 2016 12:46 PM
morteljc
Wheels/Tires
Oct 22, 2015 08:43 PM
Shock_and_Awe
Aug 23, 2015 01:02 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
