Help With 99 maxima needed. Car hesitates or the clutch is slipping. not sure anymore
Old Apr 30, 2010 | 10:55 PM
xkazik's Avatar
Help With 99 maxima needed. Car hesitates or the clutch is slipping. not sure anymore. So when ever i drive and i change into 2 gear or 3 sometimes my car just shakes after i step back on the gas pedal around 1-2 rpms after that it stops. What can this be ? if the clutch would be sleeping wouldn't it slip on the high way either . I have no codes or check engine light on. I put super in my car all the time, mobile 1 oil , spark plus and belts, fuel filter done within 5000 miles. Car use to do it less back them now its more frequent, What i noticed is that the rpms drop a lil sometimes when the car is in neutral , They drop about 50-100 rpms and it goes up really quick, and you can feel it in the car , any help would be great , any cheap sensors i can change to eliminate it ?, thx in advance
Old May 1, 2010 | 12:22 AM
MaximaSpd85's Avatar
well, at what rpm are you shifting at when you experience this? maybe coil packs? you are a 99 so that could be an issue.
Old May 1, 2010 | 06:23 AM
mrglynis's Avatar
You could try cleaning your MAF. My acts up every now and then and behaves like yours. And my clutch is definetly slipping. Its a seperate issue.
Old May 1, 2010 | 08:00 AM
xkazik's Avatar
I have a extra maf so i will changing it today and see, and its not always the same rpms but its like 1.5 rpms to 2
Old May 5, 2010 | 05:46 PM
xkazik's Avatar
still have it after maf change anyone any idea ?
Old May 5, 2010 | 06:02 PM
Spyguy's Avatar
Test each coil.
Old May 6, 2010 | 03:07 AM
Mistertones's Avatar
I had a slipping clutch about a month ago. It was hard for me to determine. But here is the post I started. http://forums.maxima.org/4th-generat...oil-packs.html
Old May 6, 2010 | 08:14 AM
xkazik's Avatar
Did u have a like a hesitation. After switching gears. On low rpms ?
Lakersallday24
Jun 16, 2019 01:35 AM
Greenmaxspeed
Aug 31, 2015 09:06 PM
MikesChevelle
Aug 10, 2015 10:53 AM
sc10692
Aug 9, 2015 09:37 AM
acw
Aug 7, 2015 04:20 PM
