Drop resistor Switch wiring
Old May 7, 2010 | 04:16 PM
hornepirate's Avatar
Im gonna wire up a drop resistor and need to know if i cut one or both of the wires ( in the picture circled in red) and soldered them to a line leading to a switch if it would work as a toggle switch
*** I dont wanna hear how I will mess up transmission blah blah blah***
Old May 7, 2010 | 05:46 PM
Nozama's Avatar
Grumpy old guy
Cut either wire and wire a switch in between the cut ends.
Old May 8, 2010 | 04:46 AM
so if one side isnt connected to anything but the switch i can still keep the circuit closed or open looped?
Old May 8, 2010 | 10:15 AM
Nozama's Avatar
Grumpy old guy
One side goes from trans to resistor the other goes from trans to switch and switch to resistor.
The switch should be normally closed and only open at WOT.
Best way to set this up is a custom bracket with a micro switch bolted onto the throttle body so the switch only activates at WOT.
The Frye
Sep 2, 2021 11:03 AM
bryants95max
Oct 2, 2015 12:52 PM
ballerchris510
Sep 23, 2015 08:46 PM
Maxie40
Sep 14, 2015 11:28 AM
Jamie Bowen
Sep 6, 2015 09:59 PM
