Sunroof not working!
Having a little problem locating the fuse and relay for the sunroof, checked the fuse box and under the hood, what is this fuse marked as? And before i start tearing the interior apart can somebody point me in the right direction to locate the relay? Checked the "how to's" and the links were not working. And of course my Tech manual, tells you it has the fuse and relay...but unfortunately does not tell you where??
Just want to rule out the obvious before i consider rebuilding the sunroof!
Appreciate it!
Appreciate it!
If your windows, door locks and cruise are fine than it's not a fuse problem because the fuses also protect those circuits. If in addition to the sunroof you also have a problem with those items than it probably is a blown fuse. There is a 7.5 amp fuse #12 under the dash drivers side fuse box and a fusible link "f" 30 Amps under the hood by the battery. The sunroof relay is located behind the drivers side kick panel.
If you want to download a service manual, go here - http://www.nicoclub.com/FSM/maxima/
Thanks for the info, my door locks and such are working fine, I have not checked the switch yet, and I will also check the relay, just wasnt too sure where it was located. thanks again, will let you know!
jerrod99_se-l
Aug 27, 2015 08:27 PM
BobMax
Aug 21, 2015 07:38 AM
BobMax
Aug 15, 2015 12:35 PM
