Random problem with the car not going over 2800 rpm
Old May 14, 2010 | 04:33 PM
maxima1380's Avatar
I have a 99 SE-L cali-spec that I have put a fed- spec manifold and o2 simulators for the extra o2's. Every since the conversion I have had a random problem with the car not wanting to go over 2800 rpm's. It is like I am on the rev limiter when it happens. Once I cut the car off and restart it, everything is fine. There is no SEL light on or anything, I'm not sure the problem is affiliated with the mod or not... Help please!
Old May 14, 2010 | 05:21 PM
NmexMAX's Avatar
dot dot dot ...
Sorry for the obvious, but it sounds like a MAF to me.
Old May 14, 2010 | 10:53 PM
ColombianMax's Avatar
I concur, sounds like MAF.
Old May 22, 2010 | 01:17 PM
4G-riken's Avatar
i had the same prob. after i re did my intake i also got told it was the maf..i check the maf readings they were fine, but it ended up being a ground point that got moved that on some starts and put me into safe mode (limp mode)
so check all the wires around the area that you workt on
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Finkle
Sep 27, 2015 09:53 PM
JMag90
Aug 25, 2015 09:17 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
