intake question
intake question
so i have just the stock intake system.... but i looked at it the other day and im missing a hose or something, and was wondering if any one could tell me what its for or where its supposed to go
its farther back a little bit and its on the bottom side of the intake hose right behind the radiator. and its before it goes into the air filter
Yeah I think its most likely the resonator tube. What I did was just find a cap or whatever that fits the hole and seal it off.
A loooong time ago I believed that opening the resonator tube would help give me more power because I'd be getting in more air, but I was wrong. Sucking in lots of hot air gave me the opposite of what i wanted.
i removed all my intake for a custom one//so i know
its the resonator tube going down to a resonator box under the batery
but yeah def. seal it off//before i re did my intake i had the same prob. i used a pvc cap for like drains and stuff painted it black so it wont stand out and put some epoxy on
good 2 go
good 2 go
I noticed a good gain in power using a maf adapter and cone filter vs. my stock air box. http://cgi.ebay.com/ebaymotors/95-96...item2eacc742ce
Or http://cgi.ebay.com/ebaymotors/1989-...item3ef93bce5b
Or http://cgi.ebay.com/ebaymotors/WEAPO...item45f17a4f6e
If you're rich.
If you're rich.
Are you guys talking about this kinda rectangularey tube:
Because I took that over-the-radiator tube off to bleed my clutch slave cylinder and I feel like that connection didn't go back on correctly. It's mad loose now, just sitting there instead of being joined by something, and I feel like it took a little tug to get it off. Is this supposed to be connected in some fancy way?
No this is for the snorkel, and mine is the same way it for some reason isn't connected in anyway to the air box, it just kind of flops around. BUT if you follow that snorkel and come to a part where a round tube goes straight down and then under the battery that is the resonator.
The resonator is basically a empty box, and it is supposed to make our engines quiet.
Was reading a thread here in which one poster does extensive testing and then defends himself and his work with a vengeance. He found the car better with the resonator sealed off. Some were cool with it, others were doubtin'/hatin', and one even suggested that the box might have been a filter for leaves/ water, etc rather than a resonator.
I'm not saying I doubt his results, but I don't think the engineers put a plastic box in the car for no reason, even if I have no idea what that reason is. Having very little interest in going fast, I am happy to leave the box on the car if the only gain is some power.
That said, I am interested in hearing my engine a bit better - the road noise I am actively trying to kill, but the engine is too quiet for my tastes. Have you noticed it any louder since removing the mystery box?
lux97Max
Sep 4, 2015 05:42 PM
Ha!
