Y-pipe VS headers
Just to clarify things, AMG did not post pics of the right exhaust for the 4th gen, they're just demonstrations to give you an idea.
And both make power, one just makes a little bit more than the other.
The y pipe is from a 6gen, didnt feel like digging. Y pipe makes very little power....headers, on the other hand, make quite a bit. Especially when you stick an 00VI on.
Not on the 4th gen. Unlike the 6th gen, the 4th gen pre-cats are in the y-pipe. Not only do the pre-cats exist but the y-pipe design to fit them in is very restrictive. Aftermarket y-pipes are easily one of the biggest bolt on power adders for the 4th gen next to the 00vi.
Ditto
http://forums.maxima.org/4910467-post27.html
http://forums.maxima.org/6410498-post16.html
Been trying to convey this point these days too.
Im aware of the precats location, as well as the crap design of the OEM Y. However, you can pick up another 10-12whp with headers over the Y pipe with a bit of Emanage Blue tuning. Im sure I could have done more with an 00vi and extended rev limit. You cant even come close with the Y pipe + E blue, as the stock manifolds dont flow nearly as well at high rpm. Toss in some cams and a PnP job and you'll see an even bigger difference. If OP doesnt intend to go that far, a Y pipe will be his best bet.
Its a simple swap over from OEM and the gains are there, and most have seen more then a simpl 1-3whp gain.
Yes, the headers make a bit more power but when a Y costs 200 vs the 600.00 for Cattman headers some may feel that extra power just isnt worth the extra cash.
To say the Y pipe just makes noise, is a bit misleading.
Curious, do you have the dyno or other documentation that shows the Y pipe and equal legnth header comparison showing the gains of before and after from the tuning?
Well by simply tuning you can pick up power without the headers and Y pipe, but for the money and time involved the Y pipe is still one of the best bangs for the buck i feel.
Edited for grammar
Isn't the Cattman headers/y pipe combo like $850 before shipping? I would look into getting some if they weren't so damn expensive. From what I read on hear a few months back when I was thinking about buying some, they seem to just make the exhaust sound better. I don't recall any significant power gains for the headers.
Edited for grammar
Edited for grammar
oh, and you can even make a stepping header design on some vehicles to tune for a different power band... thats instead of a single tube diameter on the whole header. ok im done now...
Edited for grammar
Edited for grammar
OBX used to make a pretty good setup for the 2002-2003 Maxima that was equal length as well. Only real problem was you had to slightly grind away a bit of the center member for the flex section to fit. If you were willing to part with EGR, it worked in 4th gens too. If I recall, they used to go for 350ish. If only they were still being made.
Maybe I should clarify. Equal length headers (i.e. Cattmans)
It's been greatly debated, perhaps before your time, that that particular dyno showing the 19whp from a y-pipe is not the norm. Some blame the extreme CF of the 2 comparison runs.
I used to be just like you, and after I saw the 1-3 whp gain, I was not impressed. But those were the days when we never thought even the mighty 00VI could fit Here's proof. Look at my trolling
http://forums.maxima.org/showpost.ph...1&postcount=35 http://forums.maxima.org/showpost.ph...1&postcount=45 Look at me, eating my words. It could also be because of the fact that I'm now all for every ounce of power, almost to the point to say heck with the price. I suppose after a certain amount, that's the attitude we get.
Here's one comparison, again, the gains will be semi minimal vs stock, and we could sit here all day and way our tails and hope/pray someone will dyno both on the same car . But it will never happen. And if it does, I'll be happy.
But since I KNOW a y-pipe will NOT give a consistent near 20fwhp gain in 2 different cars, I will continue to argue this until someone shows me runfiles Although Stillens 1st gen Y may be the only candidate to nip close, but until then once again.
Here's one:
Mods: Greddy muffler vs Cattman headers + said muffler.
Give me a minute while I sift through the old threads for the other.
Here's one:
Yes, we all know the equal legnth headers give gains over the aftermarket Y.
And most dynos Ive seen show the headers to give a 20+whp gain over stock.
http://forums.maxima.org/2428403-post51.html
Stephen Max's dyno even showed a 22+whp gain on his SCed setup
But the question is, how much of a gain is it over the aftermarket Y pipe?
We all know the Y pipe is not going to give the 20-25whp gain, especially after seeing the headers yeild these results. But I think its realistic to say its giving at least 8-10whp gain.
IF the Y pipe gains aretruly around 10whp, and the average gain of the headers is around 20whp Im sure most wont feel the price of 600.00 bucks above the Y pipe costs are worth the extra 10whp gained over the Y pipe.
For myself, and others who are looking to squeeze out as much power as possible thats not the case.
I have learned when modding a Maxima it is not worth it to weight out cost benefits.
And peak #'s never tell the real story.
I'm sure it's first rate china stock. Has anyone used one of these or had friends use them?
http://cgi.ebay.com/ebaymotors/1995-...#ht_3838wt_892
yes im interested in those as well. is there any test anywhere on the net?
After the fact update... my obx headers make a big difference in midrange over the y-pipe, I don't have dyno vs. dyno proof, just a but dyno and a few car owners than can see the difference though.
consider the following:1.are you paying for install on both, and even if not just based on labor time even if your own. 2. are you a dyno queen looking to squeeze the highest numbers n/a 3. is money , budget, bang for the buck an issue for you
cattman = best, but expensive, more labor intensive ($$ or time) for an added 15-20 whp over a regular 2.5 inch y pipe stock headers?? what about a custom 3 inch y pipe and still save 400-500 bucks almost enough for a 3" catback, honestly, having run a car with more than 20 whp over mines, you minus well shed a few pounds and pocket the money it wont be that serious.
tom ill post info on a 5.5 using 3.0 headers and a 2.5 budget y pipe and a 3" catback. way budget way to freeup some exhaust flow on that car.. the dyno will show the diff to what most do which is drop 800 bucks on headers and still run 2.5 catbacks,
so really you have to decide what you want and if money aint a thing, def go with full cattman,
can you even buy aftermarket headers and use the stock y-pipe. I dont know for certain, but I dont think you can
But why ask this question? If you're going through the trouble of doing headers, why only put a stock Y-pipe back on? Which could take away the benefit of your headers?
I should have taken pics of the unmodified headers installed with the crossmember. But I think the crossmember will need some grinding near the front header flange, and some hope that the rest of that y pipe goes under/clears the crossmember.
hey this one adds a whole extra cylender per bank must be ++++HP!!!
http://cgi.ebay.com/ebaymotors/95-96-97-98-99-00-01-NISSAN-MAXIMA-R-EXHAUST-MANIFOLD-/150451781732?pt=Motors_Car_Truck_Parts_Accessories &fits=Make%3ANissan|Model%3AMaxima|Year%3A1998&has h=item2307a00064
lol
lol
