Need Calipers Rear Both side
Old May 29, 2010 | 09:37 AM
hobokenkid's Avatar
need some help on parts. decided to replace the rear calipers on my 1999 maxima. I am going to do it with my friends help. I found CARDONE to be the choice. Are they decent ?,and is there a site that people like to buy parts off . No autozone -hate there stuff always have has problems. Also should i replace brackets also there rusted. also do you need a bleeder plug I see offered.Thanks again This site has helped me over the years .
Old May 29, 2010 | 09:44 AM
Bobo's Avatar
I had to replace my calipers 5 years ago because I stupidly did not use my parking brake for about 5 years and the emergency brake piston in the right rear caliper froze the caliper. I replaced the pads at the same time. The rotors were fine.
I bought the parts at a locally parts supply store, with a corporate discount, and had a shop install them.
Calipers (net of the core charge) and Raybestos pads installed were Cdn$400 taxes included. It would have been $1,000 at a stealership. Rust was not an issue.
Old May 29, 2010 | 02:36 PM
jholley's Avatar
If the caliper brackets are rusted then replace them also. They're usually around $20. Also check those guide pins that the caliper slides on. They mount in the caliper brackets.
When I replaced my front caliper brackets 4 years ago I tightened them too hard so they broke off when I loosened them last year. Put silicon grease on those caliper bracket mounting bolts.
Old May 31, 2010 | 02:17 PM
PLUMMAXSE's Avatar
Try these:http://cgi.ebay.com/ebaymotors/Maxim...item519019e600
I used these when I replaced my rears. Much easier and no core charge stuff!!
Old Jun 1, 2010 | 08:23 PM
NisMoN00B's Avatar
+Cru OG
Cardone works fine, I have them on my car.
Just go to O'Reilly Auto. You pay about $1xx for the new ones but you'll get a refund once you return the cores. And .. lifetime warranty, FTW.
Dennis Twohy
Oct 1, 2015 06:01 PM
Huttig2009
Sep 25, 2015 03:31 PM
homeyclaus
Sep 3, 2015 06:15 PM
RealityCheck
Aug 5, 2015 06:18 AM
