What would a not-fully-disengaging clutch do?
Old Jun 7, 2010 | 08:51 PM
j-dawg's Avatar
Would it:
*Make the shift lever stiff, with the engine on, off, clutch in, out, whatever
*Make my driving all herky-jerky if I was too quick off the clutch
*Make clutch uptake very finicky
tl;dr: i refilled my leaky clutch and bled it and it's good
Question time:
1. Why wouldn't fluid go into a leaky clutch system if I top off the reservoir, even with judicious pedal pumping? Does this mean that what's slowly dripping out is being replaced by air? Does this mean I'll have to thoroughly bleed my system every time I add fluid?
2. What does a burnt smell in the clutch fluid indicate, if anything? I'm not hard on the clutch, but I can't see how it would make a difference - the fluid's job is just to push or don't push as dictated by the pedal. Does it mean my cylinders need replacement?
3. Why do I have two puddles? It is just the line connecting master and slave cyl leaking and dripping off at two points? Is the best first step to take here replacing that line? If so, how hard is that? If it helps, I thought bleeding the slave cyl was pretty easy, and I have dexterous little-boy hands.
Old Jun 7, 2010 | 09:31 PM
ABlackSER's Avatar
Old Jun 7, 2010 | 10:25 PM
j-dawg's Avatar
lol ok shrunk
Old Jun 8, 2010 | 01:31 PM
bkbajan's Avatar
its called clutch drag,u probably have a contaminated clutch disc.
take the tranny apart..find ur leak,fix it..then install a brand new clutch.
idk your mechanical skill set..so attempt with caution
user 11122324
42
Jul 18, 2022 03:35 PM
Mar 12, 2020 12:06 AM
spencerwh1
Jun 30, 2016 05:44 AM
BkGreen97
Apr 2, 2016 05:47 AM
carlosvq30
Sep 26, 2015 09:44 AM
