I recently got a new engine put in and my car jerks changing gears.
Old Jun 8, 2010 | 09:06 PM
dauntlessmax's Avatar
It's a 95'. The car jerks through gears HARSHLY It never used to do this before and I'm pretty pissed, although I knew what to expect. Just lucky there aren't any idling problems or any of the other potential problems that come with the installation of another engine Also there's a check engine light if that helps with anything.
Old Jun 9, 2010 | 06:33 AM
cashoit's Avatar
posting the CEL code would help
Old Jun 9, 2010 | 02:17 PM
FallenOne's Avatar
Pull the codes, either yourself or at autozone. Also, any recent work done? How many miles? Did you seat the TC correctly?
Old Jun 9, 2010 | 02:23 PM
nismology's Avatar
Was this a high-mileage engine/tranny combo? If so, what condition was the tranny fluid in? If it was dark and smelled a little burnt, did you reuse it or put fresh fluid in?
Old Jun 9, 2010 | 04:43 PM
skypilots's Avatar
Dropping resistor
I had the same problem with a '97. I replaced the dropping resistor that is located behind the air cleaner box on the firewall. The part was $55 but taht was 5 years ago. The cel went off and it shifted so smooth.
Old Jun 9, 2010 | 04:53 PM
f550maranello2's Avatar
should have went to the junk yard and stolen one...
OP check to make sure its plugged in
Old Jun 9, 2010 | 04:54 PM
The tranny has 217k on it and the fluid was actually just replaced before the replacement. To make it more clear it only jerks shifting into 1st gear. I'm gonna take an educated guess and say it's one of the engine mounts???
Old Jun 10, 2010 | 07:42 PM
FallenOne's Avatar
awww, dude... that tranny could be garbage...
has maintenance been done regularly?
was there any significant amount of metal in the fluid or any condition in it prior?
carguy96
20
Feb 6, 2021 06:21 AM
KRMZN603
Sep 13, 2015 08:36 AM
sc10692
Aug 9, 2015 09:37 AM
maxima297
Aug 3, 2015 12:50 PM
