No 12v Power to Radio.
Old Jun 12, 2010 | 05:16 PM
OC_Nooby's Avatar
Hey
Hope someone can help...
On my Radio Harness I have a Pink/Blue wire that supplies 12v from the battery and a blue wire which is the switched 12v (IGN). Now if I measure the voltage without the radio plugged in (checking from harness) I can measure the 12v switched power but don't have the 12v power from the battery (Pink/Blue).
Fuses are OK, battery is good, I'm going to check the relay (no clue which it is) other then don't have any idea.... Anyone? I can easily fix it by just routing a cable from the battery to the radio and be done with it but that's not the way I want to do it. So any help would be appreciated. Thanks
Old Jun 12, 2010 | 05:37 PM
OC_Nooby's Avatar
Accessory Relay which supplies the 12v for the radio is OK...Damn
Old Jun 12, 2010 | 09:52 PM
NineOhSE's Avatar
Try following this to see where the voltage drops.
When you say the fuses are ok, that means all of them, right? Including the ones in the under the hood and to the left of the steering wheel?
Old Jun 13, 2010 | 06:47 AM
OC_Nooby's Avatar
I didn't check under the hood. I'll check it out. If the probable inst there ill start following the line. There is a super multiple junction where it goes from Fuse to male junction, then femal junction then to radio connector. So ill check the hood first then I'll check the junction and make sure its all good.
Old Jun 13, 2010 | 09:24 AM
OC_Nooby's Avatar
Yup, the fuse under the hood was blown. The one in the fuse panel on the drivers side (in car) was OK...Thanks!
gigabyte
Jan 6, 2017 06:05 PM
maxinout93
Oct 31, 2015 02:04 AM
leatherneck
Sep 30, 2015 09:16 PM
