5spd rebuild question
So I took my a transmission apart a while ago to rebuild it. I got busy with school and had to let it sit for a while. Now I am putting it back together and I have this little plastic funnel shaped piece known in the FSM as "oil pocket". Where does this piece go?
IIRC - if its the flat round 'funnelly' one it sits on top of the input shaft with the shims (on the bearing that has *****, not cones) There's another round one under the mainshaft race that you may have popped out, and then theres the two oil channels (one squarish little one with a tube and a long rectangular one) that slide into a groove (and sort of clip onto eachother) on the case. Check the pics, though.
I already got it back together. I was just how I had the transmission positioned on the bench that I didn't see the obvious hole down to the main shaft. Case is sealed and it's ready to be installed.
Unclejunebug
04-02-2016 05:42 AM
Pied
09-26-2015 03:29 PM
