Missfire in low rpms
Old Jul 1, 2010 | 12:02 AM
Maximum-Maxima's Avatar
This is no new issue with my car its been like this since i got it. Its starting to really bother me tho, im not sure what it is im guess a coil pack or clogged injector. But anyways i get a misfire from about anything under 2k rpm. Like say going up a hill in second or third, at around 1500 rpm it will start to misfire crazy. But it doesnt do it reving past anything above 2k rpm. i have no cels, anyone got any ideas?
Old Jul 1, 2010 | 12:44 AM
BronxSleeperMax187's Avatar
So you waited over A year and A half to fix this problem sounds like one or more of your coils or plugs.
Old Jul 1, 2010 | 03:35 AM
stamar's Avatar
what is the idle like?
you have no cel but do you have any codes?
spend $50 on a code reader i dont believe in telling people to read the flashing lights.
there are codes without the cel also.
Old Jul 1, 2010 | 07:31 AM
cashoit's Avatar
Could be a bunch of things.
Clean MAF and TB per the how tos. Check CPS, TPS, CKPS. CHeck coils. Prolly change spark plugs. Check PCM.
Old Jul 1, 2010 | 08:05 AM
I cleaned the TB and replaced the spark plugs just recently. CPS is good but ill check the others you listed.
Old Jul 1, 2010 | 08:30 AM
RA021526's Avatar
Before spending money on a code reader, grab your multimeter. Search for how to test your coils and fuel injectors, it should be a resistance test. Misfires can be more apparent at lower rpm levels and are less noticeable at higher levels.
Old Jul 1, 2010 | 09:36 AM
99zx2's Avatar
check your maf!
Old Jul 1, 2010 | 01:22 PM
stamar's Avatar
Before you invest in gasoline you should invest in a code reader.
Youre just not gonna make it long term with a car you cant diagnose with one, clear the codes.
I feel the need for one with freeze frame info too.
Code reader or get in shape for a bicycle. Todays cars need one and they are cheap now.
Old Jul 2, 2010 | 03:00 PM
Trini Boom's Avatar
If you are at idle and you feel a small jolt from time to time, more than likely its your coils going bad. They are failing under load and the multimeter would not help you finding it. My trick I did was put it in D with parking brake all the way up and chuck the back wheel. It should still be jolting if its bad. Unplug the coils one by one. The engine will shake but also you would feel the jolt still you unplugged a good one. Keep going until you find the one that does not make it jolt and that's the defective one.
Old Jul 3, 2010 | 12:57 AM
Yeah ive read about this, one thing tho my cars stick. But ill try it at idle.
Old Jul 3, 2010 | 06:09 AM
Trini Boom's Avatar
Hmm...yeah that's going to be difficult. But let us know if it helped you out. It may also be more than one if you can't find just one.
Old Jul 3, 2010 | 09:28 AM
asand1's Avatar
COMPRESSION TEST
Do a compression/leakdown test. A burned exhaust valve will cause a miss at idle and feels like it cleans up cruizing. Will get a bad miss again when pulling. A bad injector could cause a burned exhaust valve BTW.
Old Jul 3, 2010 | 10:02 AM
NaxalMax97's Avatar
I've been having similar issues with my 97 Max (150K Miles). Misses bad between 1200-1800 RPM while going between 30 and 40 mph. Will also miss at idle and warming when warming up, and there is hesitation upon attempted acceleration.
I sent my fuel injectors off for sonic cleaning (Witch Hunter), according to their data the injectors were a non-issue. Also thoroughly cleaned the throttle body, EGR Valve, EGR Guide Tube, IACV...
I suspect a failing coil pack. Won't know for sure until everything is reinstalled though (having installation issues). Been going on for about 6 months now.
Old Aug 27, 2010 | 04:46 AM
I think i found my issue if the coilpacks are grounded off the valve cover then thats it. Because my valve cover is painted and i dont think its getting a good ground.
Old Aug 27, 2010 | 06:56 AM
ajm8127's Avatar
The coils are grounded through pin two of their respective connectors and that ground runs to the top of the lower intake manifold on the passengers side of the engine.
Old Aug 27, 2010 | 09:33 AM
PGB25's Avatar
fuel injectors
Unclejunebug
Apr 2, 2016 05:42 AM
ef9
Oct 4, 2015 08:43 AM
Need help
23
Oct 2, 2015 08:56 AM
