inner tie rod boot crack
Old Jul 4, 2010 | 11:16 AM
99zx2's Avatar
hey, all! happy 4th to you
It rained yesterday, and after it stopped, i've noticed the car had a creaking sound coming from somewhere under the hood when the wheel was being turned. It turned out to be a pass. side inner tie rod boot had a crack in it, and i assume the grease has been leaking out of it (the rain didn't help either).
So, my question is: does anyone know where to find the new boots? not sure if the tie rod is shot or not. if it is, i'll change that as well.
Thank you, all!
p.s. just did some searching: turns out it's called a steering rack boot autozone has them for $24. should i replace both inner and outers while i'm at it?
Old Jul 4, 2010 | 12:07 PM
asand1's Avatar
Jack that side up by the control arm, as close to the ball joint as possible. Grab the tire at 3 and 9 O'clock. Shake to check for loosness in the tie rod. If its tight, replace the bellows (boot) using new greese. Smear some grease in the joint as best you can. Youll have to seperate the inner and outer joint from each other, count the turns and reinstall at the same #.
Do it soon, before the rack suffers damage.
Old Jul 4, 2010 | 12:09 PM
99zx2's Avatar
i've had loose suspension parts on my other car and the wheel method hasn't revealed anything. i guess, i'll just replace both inners and outers, since i'm gonna bet there. anything else to check for while i'm there?
Old Jul 4, 2010 | 12:15 PM
asand1's Avatar
Check the boots on your ball joint and sway bar end-links, Check your brake line for cracking while you have the wheel off. Look around paying special attention to rubber parts.
I suspect that it is the inner tie rod making noise, but it could also be a ball joint or strut mount.
Old Jul 4, 2010 | 12:38 PM
schmellyfart's Avatar
I bought mine from here for ~$8 each. http://forums.maxima.org/group-deals...arts-sale.html
Old Jul 4, 2010 | 01:14 PM
99zx2's Avatar
thanks for the advices, guys! i'm gonna try to do it tomorrow, so i'll get everything from az. I thought i had the grease leaking from it, but it turned out to be the a/c drain that is right above the boot. Not sure how long it has been torn and that water that has been draining on top of it, but sure long enough to start producing that "creak."
user 11122324
42
Jul 18, 2022 03:35 PM
knight_yyz
Nov 1, 2015 01:34 PM
Andy29
Sep 29, 2015 05:32 AM
londonflu
Sep 19, 2015 02:33 PM
