A/C Problem
Old Jul 7, 2010 | 10:54 AM
Fenton3030's Avatar
A/C Problem
don't know what to do about this a/c
the a/c only works correctly through the middle vents
the side vents closests to the door seem to always be two levels below the middle
IE: if the a/c control is set to speed 1 the side vents blow nothing and the mid ones blow correctly and when i put it to speed 3 where the middles blow accordingly and the sides feel like speed 1
Old Jul 8, 2010 | 12:50 PM
cashoit's Avatar
new blower resistor??
Old Jul 8, 2010 | 01:10 PM
ColombianMax's Avatar
Sounds like the vent doors that regulate air are opened for the mid but not the outer vents. I've never looked at the maxima's vent doors but I know that grand cherokees are very prone to having those break and you can only get air from certain vents and sometimes it'll stay on heat or cool depending where it was last before it broke.
Are you sure that the wheel below the outer fans isn't set to closed?
Old Jul 11, 2010 | 06:02 PM
onebadmax666's Avatar
i wanna get the y pipe dose it make a difference
Old Jul 11, 2010 | 08:27 PM
Fenton3030's Avatar
yeah the outer srttings wheels are set all thw way to open
Old Jul 11, 2010 | 11:16 PM
Might have to take a few things apart such as the glove compartment and check if the vent doors are moving when you change the setting on your climate control
Old Jul 12, 2010 | 06:54 AM
cashoit's Avatar
some a/c is better than no a/c lol
Old Jul 12, 2010 | 08:47 AM
Fenton3030's Avatar
okay taking it into the shop tuesday just tgought id post my prob here firsr in case this was a common prob for maxs thanks for all the replies as always max.org 4ever
Old Jul 14, 2010 | 05:20 PM
93SCMax's Avatar
98 SE
You didn't indicate whether you have a manual or auto climate control system. It may make a difference.
If you have an auto system, I'd recommend runnning the self diagnosis test (page HA-70 in FSM). This could clarify if the vent door acutuators are working properly. Best first step before spending $ at a dealer, or disassemblying components.
Old Jul 14, 2010 | 07:40 PM
max ride 41's Avatar
dude, wtf does this have to do with the thread at hand????? go thread jack somewhere else, we do have a search feature in these forums... :matt93se:
Old Jul 14, 2010 | 08:12 PM
Fenton3030's Avatar
i believe i have the manual one with the **** on the left with numbers 0-4
Old Jul 15, 2010 | 06:56 AM
cashoit's Avatar
I saw that kid's post too and was like WTF
nice! maxride enforcer!
Old Jul 15, 2010 | 02:05 PM
93SCMax's Avatar
98 SE
Need to do Preliminary Check #2 (FSM, page HA-27) If the compressor works (yes), refrigerant is good (yes?), then you need to visually check the air mix door motor and linkage operation (see HA-50). Unfortunately, you will need to visually inspect the air mix door by removing the instrument panel.
If you can access a FSM, it may help you determine if it's the air mix door w/o disassembling 1st.
It may be something as simply as the side ventilator duct have come partially disconnected or isn't making a full seal back to the heater/blower.
Good luck
Old Jul 16, 2010 | 10:50 AM
Fenton3030's Avatar
Good luck
THANK YOU get to this when i have the time
BkGreen97
Apr 2, 2016 05:47 AM
Turbonut
46
Oct 21, 2015 08:28 PM
mclasser
Sep 24, 2015 11:57 PM
pears
Sep 18, 2015 05:25 AM
EdRomo86
Sep 12, 2015 07:49 PM
