HELP- Cooling Fan Stopped Working
Old Jul 19, 2010 | 06:07 AM
JiggsHall's Avatar
Last week on the HOTTEST week of the year my cooling fan suddenly stopped working, and it appeared that my car would overheat. Has this happened to anyone before ? How can I tell if I just need to replace the relays , fan motor, or the complete fan ?
Old Jul 19, 2010 | 06:21 AM
Trini Boom's Avatar
Swap the relay with another one thats in the fuse box. Can you spin the fan freely by hand or is it stiff??
Old Jul 19, 2010 | 06:24 AM
99zx2's Avatar
did it appear to overheat while idling or driving? take the connector to the fan(s) and apply power to it, ruling out the fan itself (motor). if it works, test the harness for power, should be around the bat's voltage.
one easier way to rule out the faulty fan: turn your a/c on and it should come on (assuming you have a proper charge).
Old Jul 19, 2010 | 06:39 AM
jholley's Avatar
Check the fusible link box next to the battery. The fan relays have 2 fusible links. One feeds fan relay 1 for low speed while the other feeds fan relays 2 & 3 for high speed. You will visually see if those 30A fusible links have melted or not.
Old Jul 19, 2010 | 07:08 AM
JiggsHall's Avatar
It happens the most at idle. Usually at red lights, or drive thrus, etc. The A/C works sporadically. It will stay really cool when the car is moving but when I stop , it begins to blow in warm air.
Old Jul 19, 2010 | 07:15 AM
99zx2's Avatar
ok. do the fans come on when you turn the a/c on?
Old Jul 19, 2010 | 07:19 AM
cashoit's Avatar
u have to test them all. First jus disconnect connector from fan and apply battery voltage to it. See it starts up. If not, then u know its the fan.
If fan work, test grounds, connectors, continumty from fan to relay, check relay.
FSM pages, EC-433-448
Old Jul 19, 2010 | 07:36 AM
JiggsHall's Avatar
The fans do not come on when the A/C is on.
Old Jul 19, 2010 | 07:41 AM
cashoit's Avatar
Yeah but that couyld be a bust fan OR busted relay. THats why i sd to test fan first to see if that broken. Jus remove the connector on the fan, and apply battery voltage. BE careful not to cut yur hands off.
Or test relays first. Its up to u man.
Old Jul 19, 2010 | 07:46 AM
JiggsHall's Avatar
Thanks for the help, I'm going to check both and let you know the results.
jerrod99_se-l
Aug 27, 2015 08:27 PM
MidnightMaxima_22
Aug 19, 2015 01:01 PM
doobadoo
Aug 15, 2015 06:43 PM
kirkhilles
Aug 8, 2015 10:53 AM
kenc15
Aug 5, 2015 08:29 AM
