didnt get the answer i wanted in audio section
Old Jul 20, 2010 | 07:52 AM
1997MAXZ's Avatar
so here is whats up
~So I was driving yesterday and my Sound started cutting out as far as Interiors and then finally went out completely. Funny part is subs still on. Head unit is on.
~Also its a 97 gle stock bose with RCA adapter in trunk for amp signal to subs.
~again it blew the "Bose" fuse at low volume.. why nothing has changed in the past few days or years for that matter and now blowing fuses in 2 mins. again head unit and subs on>>> please help i cannot get a new hu right now..
YYY
Old Jul 21, 2010 | 08:46 AM
aznstormin's Avatar
Check the fuse on the amp?
What is cutting out in the interiors? The lighting? AC controls? Check the connections to the battery?
Old Jul 21, 2010 | 10:23 AM
1997MAXZ's Avatar
The interior speakers.
The fuse labeled Bose on the interior fuse panel - 15a- fuse is the one blowing
what is this fuses particular purpose
obviously I know when it blows I have no sound out of the speakers but is it tripped by the stock bose amps or what is up
Old Jul 22, 2010 | 03:52 AM
1997MAXZ's Avatar
please
got 600$ quote for new hu and speakers. dont have the dough right now
going nuts without any tunes
Old Jul 22, 2010 | 04:09 AM
MAXIMA_STYLE's Avatar
600 for a new headunit with speakers? thats retarded!!! you can buy a headunit for 100 bucks at walmart add in 13 for the kit to install and another 10 for the harness, wire it all together and turn it on, if you still got no sound from speakers i suggest taking it to a repair shop because chances are you got some sort of electrical problem
Old Jul 22, 2010 | 04:23 AM
1997MAXZ's Avatar
well being that the stock speakers regardless are 13 years old and definitely not lets just say in there prime, I figured the car would already be in the shop so why not replace them.
I still just want to know the direct function or what the "BOSE" labeled fuse directly powers.
Old Jul 22, 2010 | 08:26 AM
Maxtank's Avatar
My guess is the Bose fuse drives all the amps for the Bose speakers, and you most likely are over driving the speakers and/or amps. The Bose speaker/amp combo is not meant for an internal amp head unit. This is typically why we have to replace everything when the HU is replaced. Power and resistance is very different w/ Bose systems than your normal aftermarket 4x40W HU.
I'm guessing your interior speakers were loud at low HU volume?
Old Jul 22, 2010 | 09:57 AM
1997MAXZ's Avatar
the speakers amps that drive the speakers and hu are all stock so I dont think I could over drive them. I just dont know why that fuse keeps blowing
and they were not any "louder at low hu volume" then any other time
Old Jul 22, 2010 | 10:01 AM
AlexxSCM's Avatar
maybe two wires are touching... my friend's stereo had two lose wires behind the headunit and burned the fuse everytime....
Old Jul 22, 2010 | 10:04 AM
1997MAXZ's Avatar
well I never took the hu out of this car. is it difficult. any step by steps. I dont want to crack any of the surrounding panels
Old Jul 22, 2010 | 10:46 AM
1997MAXZ's Avatar
ok so i got the whole thing apart in like 2 mins but i dont see any wires touching or loose etc. I will go get a new head unit right now, but from what MaxTank said that fuse that is blowing has to do with the bose amps. First is this true and second who thinks if i get the new hu and wire kit my problems will be solved??
Old Jul 22, 2010 | 07:31 PM
FallenOne's Avatar
im not going to bother reading anything posted above.
The steps you need to take are as follows.
1. Confirm the Fuse rating for the radio is correct, this is listed on the fuse panel door.
2. Try unplugging the Line Output Converter that sends the low level signal to your Amp.
3. Try unplugging Bose amps, 1 at a time see if anything changes.
4. If all else fails, try a new Bose Headunit.
5. Check Wiring. Yes, a PITA I Know.
Old Jul 22, 2010 | 09:30 PM
beegeezy77's Avatar
The bose fuse is for the +12v power wire for the 4 bose amps. The radio staying on and the sub staying on tells me that your signal from the deck is fine. (must have caught the speaker level connection before the amp(s))While it could be a wiring problem it could also be that one or more of the bose amps is failing. They're old and they suck anyway. You can get a new radio and front/rear speakers for under $200. I wouldn't put one penny into the bose system.
Old Jul 22, 2010 | 09:59 PM
jdooley's Avatar
Someone here recently posted instructions, or at least a parts list, for replacing the electrolytic capacitors in the Bose amps (1 at each speaker). It would only take one shorted capacitor to take out that fuse so like FallenOne suggested, isolate the amps by unplugging one at a time (or unplug all and plug them back in one at a time) until you find the one one that needs repair/replacing. If you know anything about soldering, they are not difficult to replace.
Personally, I have no issues with my Bose at all. I think it sounds better than your typical stock radio at this price level.
Old Jul 23, 2010 | 02:44 PM
FallenOne's Avatar
I am so terribly sick of people just saying throw 200$ at fixing a problem that can be fixed with little time and/or money!
If your just going to say buy new **** :matt93se:!
And for the record our 12 year old Bose Is Not That Bad!!! Just cause your headunit sucks doesn't mean the speakers suck!
LOW LEVEL OUTPUTS
AHHHH!
Old Jul 23, 2010 | 03:27 PM
beegeezy77's Avatar
LOW LEVEL OUTPUTS
AHHHH!
You're right, he can probably fix the problem for less than what new speakers and a radio would cost. I was an mecp installer for 7 years and I could troubleshoot the problem...but can he? My point is that if you have to pay someone to diagnose the bose system why not replace it instead? Even if you could fix it for relatively little money isn't new equipment with features like an ipod interface and bluetooth a better option? I have replaced enough bose systems over the years to formulate a pretty solid opinion that nissan/infiniti car audio systems suck. Just my opinion though...
Old Jul 23, 2010 | 05:56 PM
snicklefitz's Avatar
loose speaker wire maybe?
well my max does not have the bose...nor did my altima but...i do remember one time on my way from PA to FLA all my speakers shorted and stopped working....drove halfway there and couldn't take it anymore......turned out one of the rear speaker wires was shorting ...and that knocked out every speaker in the car....again that was my altima . i would wiggle your wires through the trunk on the rears and see if you get anything ....good luck
Old Jul 23, 2010 | 06:27 PM
TravisCadello's Avatar
mine did the same thing! about 3 months ago my bose just stopped working i put new fuse in and it worked for 2 hours and then blew again and i bought a pack of fuses and they all blew as soon as i turned over the key.
i gave up and spent $650 to have a pioneer cd deck installed all my speakers rewired so the bose can be bypassed and a 300 dollar amp to my two twelves.
let me tell you these front bose 6.5s and tweeters take some POWER! their from 95 and they jam chrystal clear compared to how my bose pushed it. 50wx4 stereo. 1000watt goin to subs.
Old Jul 23, 2010 | 06:52 PM
FallenOne's Avatar
How is this relevant?
Oh and By The Way.
Bose Speakers are Amplified at 1 Ohm.
So Sending a High level Signal at say 4 Ohms? Will just sound like total Azz by sending a high level signal to Low Level Inputs. Or a 1 Ohm Driver on 4 Ohm Speakers will either blow your headunit or your speakers due to under powering them or making your headunit run at 1 Ohm Nearly Doubling or even Quadrupling the Maximum output that the Headunit was made to withstand.
I can go all day.
vybz05
Dec 10, 2015 07:38 PM
PSU09MAXIMA
Aug 28, 2015 12:47 PM
Slamrod
Aug 10, 2015 12:33 PM
MikesChevelle
Aug 6, 2015 11:36 AM
