4th Gen 99 Maxima GLE Lot's of Problems
Hey Guys I've been searching around here since I've fired my mechanic and refuse to shell out a mortgage payment to these stealerships, dead beat local shops and chains.
This is what I brought for $1k with 93k miles at the time of purchase, she has 113k miles on it now.
I brought her with damage to the right fender, hood and rt side marker lights missing.
Had the fender replace with brand new, hood repaired, purchases clear diamond bumper lights and got a side marker light at the junk yard and painted half the car all for $936.00 Total.
Making a purchase price of $1936.00 I thought at that time I had a great deal until mechanical things began to happen.
The alternator was going bad so I took it too Nissan Dealership in my area and was quoted a way out there f8ckin mind price well seeing what I spent in labor after going to a back alley mechanic I might as well paid nissan. I went thru five alternator in 1yr @ $70 each to install. The six alternator I put in myself last week thanks to the org.
I knew I couldn't afford a stealership nor did I trust local shops and those chain shop love to up sale for other stuff you don't need with scare tactics. So I'm asking if the car is worth everything else that needs to be done.
Engine:
Knock Sensor (needs)
EGR tube cleaned (needs)
Alternator (done six times) sixth I did myself
Starter (done)
new plugs NGK Plat (done myself)
Coil pack (3 fronts done myself)
fuel filter ( done)
air filter (done)
PCV (needs)
Trans:
fluild change (needs) a little brown color right now
Filter (needs cleaning or replaced)
Axles (needs both)
note: works ok at this moment
Suspension:
Ball joints (needs)
Sway bar Bushing (needs)
Sway bar Links (needs)
Shocks/Struts (done)
Springs (not sure if I need to replace)
Tie rods ends Inner and Outer (needs)
Brake:
rear rotors (done myself)
rear pad (done myself)
rear caliper (I rebuilt myself)
Front rotors (need)
Front pad (should replace with new rotors?)
Front caliper (look good but will service myself)
any suggestion will be taking grateful and appreciated. Oh and any locals of Baltimore would love your assistance.
Thanks in advance
Engine:
Starter (done)
fuel filter ( done)
air filter (done)
PCV (needs)
Trans:
Axles (needs both)
Suspension:
Ball joints (needs)
Brake:
Front rotors (need)
Thanks in advance
Engine:
Starter (done)
fuel filter ( done)
air filter (done)
PCV (needs)
Trans:
Axles (needs both)
Suspension:
Ball joints (needs)
Brake:
Front rotors (need)
Starter (done)
fuel filter ( done)
air filter (done)
PCV (needs)
Trans:
Axles (needs both)
Suspension:
Ball joints (needs)
Brake:
Front rotors (need)
Front axles: $128.00
Front rotors: $40.00
Front Pads: $ 30.00
Struts: $ 248.00
Belts: $40.00
Gear oil change: $60.00
Rear Caliper Brackets: $40.00
TOTAL: $586.00
We all reach the turning point with these cars, especially when they were 10+ years old. To me, the repairs are worth it for a very reliable car.
If you are going to do everything yourself, it is definitely worth it. Everything on your list is typical for the mileage/age of your car. Why don't you price everything out in a spreadsheet and see if it is worth it to you. If it adds up to 5000.00, would you be able to find a 5000 dollar car in that sort of shape with as many new parts? Probably not. Here is what I am doing to my 1999 Max to keep her going (All myself):
Front Pads: $ 30.00
Struts: $ 248.00
Belts: $40.00
TOTAL: $586.00
Front Pads: $ 30.00
Struts: $ 248.00
Belts: $40.00
TOTAL: $586.00
Yeah. I have the 5-speed. 132,000 miles too. I bought it with 90,000 miles and only had to do a coil pack and exhaust in that time.
I got the axles from advance auto. The brand is GSP, which many orgers advise against, but they have a lifetime warranty and they are new, not reman's. I baby my car and it isn't lowered, so I am not worried about wrecking them.
I also forgot to add a fan relay to the list. I need this soon.
BTW, your car is in great shape cosmetically.
Listen man, that car is worth keeping and fixing.Your problems are minor but the issue with the alternator blowing out 6 times in a year, is an issue that should have been checked by the mechanic that worked on the car. Absolutely there is a problem with the charging system which needs to be rectified. How are the alternators dying?? Did you ever replace the battery during the times you replaced all 6 alternators??
I'm sure you can find a maxima guy or guys in your area to help you out with anything you need done to it provided you have pizza and beer on hand. I dont know what you americans eat on such occasions but beer, pizza and the occasional post work kush does the job for us canucks
p.s. it's a great way to learn and to start knowing your car.
Thanks guys for the confidences... I really didn't realize what I have. I was almost about to sell her and was thinking of selling $2500 OBO. no dice now!!!! anybody in the Baltimore area willing to look at her and tell me what they would do next?
keep the car man, AND PLEASE CLEAN IT UP, leather treat those seats and shine them up mine turn out sooo damn clean after a clean. trust me all those problems are minor. that car is good for another 200,000 miles,its fully loaded also man its nice inside.
i have 295k miles, original motor i race it a lot and drive 120 miles a day monday through saturday. what have i done to this car? everything is original except except regular wear and tear items.
i just found out i got original 1995 295k mile alternator OEM and i got a 2000 watt stereo system. go to dealer and buy OEM alternator or go to junkyard and see if their s OEM in one of them. i hate remans waste of time.
the last 95k miles i have had ZERO problems. only thing i do is my oil changes. the only major work i had to do is the tranny gave at 280k miles because i was doing burnouts in 2nd gear and trying 3rd gear and screwed it allll up. i have driven the hell out my car and only changed minor stuff.
i have been through lots of cars and trust me these maximas are like the ost durable cars out their.
oh and to make you feel better i been driving with bad knock sensor for over a year and a half and still getting 20MPG and still smoking new Impalas,jettas,malibu cars with bigger motors then me and 1/4 the miles of my motor. im proud of the maxima and definitely will have mine for a while.
Yea I do have one code... I can't remember what is was right now. but I know it had something to do with faulty curcuit and it has a miss fire somewhere but there no codes for where or maybe that one code has something to do with that.
Like everyone said man, keep it and fix it. Let it be your learning car and dont be afraid to break anything as you do have us
Basically, if you go down that list and compare to your current mileage.. its all really just routine maintenance and if some of that stuff is original (which I'm almost positive it is) then it certainly is overdue and actually lasted longer than the replacement intervals are. Just replace the parts and you'll probably never have to replace them again for a very long time. Unless you get ****ty aftermarket parts. Stick to OEM and you'll own this car for many years to come.
Paying 4K for mine (but it's in really good 'Mechanical' shape, and has a JWT ECU).
Seriously nice looking Maxima.
Mine is nearly 190K right now... bought with 184K on it. .....
Once you know the basics of 'maintaining' your Maxima - you'll find it to be a great car, and you got yours for a STEAL. As for the Alternator... get a lifetime warranty - and they replace it (you install)...
Did a interior clean this week... you guys told me to clean her up. So the process has began...LOL
rear seat cleaned and conditioned
Fronts cleaned and conditioned and reinstalled.
Next I will clean the engine, finishing off with Clay Bar and glazing of the paint finish. Pic of that once done.
Any other things I maybe forgetting let me know
Thanks guys
Note: Pic are awful I will be doing new pic in digital or HD of the finished works
im glad you decided to keep her, as everyone else said multiple times these are reliable cars if properly taken of, they'll last you longer than any of these new cars will. after your done with all the cosmetic stuff then you can throw in a 00vi and then some lol. good luck and keep us posted.
Your '99 really isn't that bad off -- keep at it! My '95 was recently in a similar state, and with a little bit of help from my father-in-law, it's condition has improved substantially and I've completely weaned myself off the local mechanic I had been using to keep it running. I feel a lot more confident about the car now after doing these repairs myself and don't see any reason why it won't go another 150K.
Thanks guy for your feedback
Finkle
09-27-2015 09:53 PM
Greenmaxspeed
08-31-2015 09:06 PM
Greenmaxspeed
08-08-2015 12:39 PM
